![]() | Home > Puma (Tdci) > Refurbished Injectors - Are they worth it? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
What can be refurbished on these types of very high pressure injectors? I genuinely don't know, not being sarcastic. Is it more than just spraying them with carb cleaner to get the dirt off? 2007 110 TDCi Station Wagon XS
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
We have these guys down in Oz.
They fit new needles that are ceramic coated. https://www.baileysdiesel.com/shop/bluepri...nder-2-4l/ Mark |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
I've never had any luck with recon injectors... times have moved on since tdi days, but a lot of recon places haven't.
For Tdci 2.4 or 2.2 I would always use new - which will also have the correct calibration code to put into the ECU. No need to go genuine - just OEM. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Hi Porny, Many thanks for your advice. Without putting you on the spot can you recommend a good supplier to get them from? Ive seen prices for new ones ranging from £ 180 to over £ 400 per injector!!
Many thanks again. |
I can do you brand new OEM injectors for £155 + vat each (if buying 4)
This includes all new seals. Only additional thing needed is 2 new clamp bolts which are £8 + vat a pair You will need to get the injectors coded into the ECU once fitted and Pilot Learn redone. Fitting is easy - as long as the old injectors come out. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Hi Ian,
PM on its way. Many thanks Steve |
keath Member Since: 02 Mar 2016 Location: Barwon Heads Posts: 5 ![]() ![]() ![]() |
If you don't mind me asking, where from? |
Keath - from me. Drop me a PM if needed.
Regards Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I can vouch for Porny's work if needed
Hi Ian, Check your PM's. Cheers. |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Definately go new Ian at IRB can do them at a decent price circa 120-130 iirc 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Ian @ IRB is Porny, above.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Would you be able to quote part numbers?
Cheers, Peter |
OldDD Member Since: 17 Jan 2016 Location: Ballaugh Posts: 54 ![]() ![]() ![]() |
Porny
I'd be keen to know more about the Injectors you offer - Can you pm me the spec please?? Do you have them in stock?? |
