Home > Td5 > Battery warning light
excossack
Way back in July on a trip to Scotland the battery warning light came on. A day later the battery warning light went away and stayed off for the whole trip and the run home.
Fast forward to last weekend, 150 miles up the M62 and all good. Ran round the forest all well. Heading home, and hello battery warning light. Stayed on for around 60 miles.
Day later all well. Mon, Tue and Wed AM to/from work all good. Drive home tonight and stop at the shops. Back in the car to come home and battery light on. Stayed on for the 1.5mile drive home.
Been under the bonnet tonight and checked the output from the alternator 12.23v with engine running. (assuming the 13mm nut on the alternator/brown wire to the starter is the output)
To rule out any other odd wiring issues on the positive side, I decided to undo the brown cable from the starter end and start the car up. Battery warning light on (to be expected given the cable is disconnected) 0v at the 13mm brown wire at the alternator.
Was this a fair test or is there another feed back to the battery I have missed?
I am thinking alternator is duff...? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #732769 3rd Oct 2018 6:42pm
grafty99
Would be worth checking the charge voltage at the battery but anything under about 13.5v charge voltage is too low Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #732771 3rd Oct 2018 6:49pm
excossack
Around 12.x volts. Something not right. I can see the volt meter dipping in time with battery warning light, 1999 Defender TD5 110
Regards
John M0VAZ
Post #732772 3rd Oct 2018 6:51pm
grafty99
I think the Td5 alternator is a 14v unit so 12v is way too low Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #732773 3rd Oct 2018 6:52pm
miker
You should get 13.5V at the battery, up to 14.1V when it's cold.
Post #732774 3rd Oct 2018 6:57pm
excossack
Cheers for the replies.
When the battery light is not on i would normally get 14.5v ish volts.
Would you expect to get a voltage output from the 13mm nut connector on the alternator with the brown wire disconnected & engine running? 1999 Defender TD5 110
Regards
John M0VAZ
Post #732785 3rd Oct 2018 7:51pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Had this on mine....had to replace alternator Shocked
Then battery started to go so replaced that as well Big Cry
Post #732805 3rd Oct 2018 8:46pm
excossack
This morning, about 3 miles into the trip to work, all well, no battery light. Then bing! on / off for the rest of the 1mile to work. Sad
New alty to be ordered me think Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #732849 4th Oct 2018 8:14am
excossack
New Denso alternator ordered. Any tips for dealing with oil drain hose? 1999 Defender TD5 110
Regards
John M0VAZ
Post #732916 4th Oct 2018 1:42pm
Tommo
Good choice re alternator...LR ones (TD5) were denso.
Still got my old one and plan to get this refurbished.
Post #732947 4th Oct 2018 4:31pm
excossack
I was pondering the option of a Bearmach/Allmakes for a bit less, but 'charged' on and made the 'positive' choice of Denso. I have seen repair kits for them, get this done and tested followed by a repair. 1999 Defender TD5 110
Regards
John M0VAZ
Post #732952 4th Oct 2018 4:52pm
Procta
I would say its the alternator too, They do daft things when they start to go on the blink. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #732992 4th Oct 2018 9:27pm
tony.g
I got a Britpart alternator a few months ago and even after several hours could not get the thing to fit. Had to give up and got a Denso one from the dealers and it went in straightaway.
The aluminium casing on the Britpart one didn't look as fine and neatly cast as the Denso.
Post #732995 4th Oct 2018 9:39pm
excossack
Job done. New alternator on. The one I took off was an original LR one, so could be the original one. If so, its done 210,000 miles!
Fitting time around 2 hours. Lets see how the work run goes. 1999 Defender TD5 110
Regards
John M0VAZ
Post #733477 7th Oct 2018 4:53pm
discomog
Good luck with the run to work tomorrow. Keep us all posted. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #733486 7th Oct 2018 6:07pm
