![]() | Home > Td5 > Battery warning light |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Would be worth checking the charge voltage at the battery but anything under about 13.5v charge voltage is too low
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
Around 12.x volts. Something not right. I can see the volt meter dipping in time with battery warning light, 1999 Defender TD5 110
I think the Td5 alternator is a 14v unit so 12v is way too low
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
You should get 13.5V at the battery, up to 14.1V when it's cold.
Cheers for the replies.
When the battery light is not on i would normally get 14.5v ish volts. Would you expect to get a voltage output from the 13mm nut connector on the alternator with the brown wire disconnected & engine running? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Had this on mine....had to replace alternator
![]() Then battery started to go so replaced that as well ![]() |
This morning, about 3 miles into the trip to work, all well, no battery light. Then bing! on / off for the rest of the 1mile to work.
![]() New alty to be ordered me think ![]() Regards John M0VAZ Econet Station 48 no clock |
New Denso alternator ordered. Any tips for dealing with oil drain hose? 1999 Defender TD5 110
Good choice re alternator...LR ones (TD5) were denso.
Still got my old one and plan to get this refurbished. |
I was pondering the option of a Bearmach/Allmakes for a bit less, but 'charged' on and made the 'positive' choice of Denso. I have seen repair kits for them, get this done and tested followed by a repair. 1999 Defender TD5 110
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5331 ![]() ![]() |
I would say its the alternator too, They do daft things when they start to go on the blink. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
tony.g Member Since: 25 Aug 2017 Location: uk Posts: 23 ![]() |
I got a Britpart alternator a few months ago and even after several hours could not get the thing to fit. Had to give up and got a Denso one from the dealers and it went in straightaway.
The aluminium casing on the Britpart one didn't look as fine and neatly cast as the Denso. |
Job done. New alternator on. The one I took off was an original LR one, so could be the original one. If so, its done 210,000 miles!
Fitting time around 2 hours. Lets see how the work run goes. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
Good luck with the run to work tomorrow. Keep us all posted. Defender 90XS SW
