Home > Wheels & Tyres > Well that's Tyre-ing...
geobloke
Oh my well that's a good place to begin the day...
It's like Sophie's choice but with BF Goodrich's... To pull or not to pull that's the question... Leave it in and it could get worse, take it out and it could get worse... Rolling Eyes
How did that little thing manage to slot straight down the sipe and not just get flicked out of the way by the tread block...
Big Cry Rolling with laughter Big Cry Rolling with laughter
I guess the real question is? In the Forum's experience and assuming that the screw has penetrated through the tyre. Will this be salvageable with a plug?
Post #732361 2nd Oct 2018 8:28am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I believe legally a tyre repair can only be effected in the middle three quarters of the tread.
Yours looks like it might be outside that area, however, without measuring I couldn't be certain.
There is also the possibility that it is a really short roofing type self tapper and may not have gone past the tread depth.
Good luck in whatever choice you make regarding leaving or removing. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #732363 2nd Oct 2018 8:34am
I wouldn't drive about with that left in, certainly not on the front.
I would unscrew it, if the air follows fit the spare and either get it plugged if a reputable tyre dealer will do this, or fit a tube. I have extracted screws from BFGs which have been longer that I thought possible without air loss.
It is a constant source of mystery to me how screws penetrate tyres since they lie flat on the road, yet always the point seems to penetrate directly into the tyre. How does this happen?
Post #732373 2nd Oct 2018 9:00am
grafty99
I'm with blackwolf, remove and see if any air come out. It may create a puncture that isn't there if you leave it in Thumbs Up (unless it has in fact already gone though) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #732375 2nd Oct 2018 9:06am
geobloke
Ok... Out with the Leatherman it is then... Thumbs Up
This is after all why you carry a spare.
Post #732378 2nd Oct 2018 9:13am
donmacn
That's such a pain, isn't it? A tiny part of an otherwise perfectly good tyre.
I had a similar situation at a filling station in Orkney once, on the VW type 2. The previous owner had fitted chrome minilites and big tyres. Looked really good. Noticed a bit of metal in the tyre while filling the tank, started to prise it out, and "hissss". Sh*t! 5.15pm on a Saturday afternoon. Luckily I was 50 yards from a tyre repair shop. I tapped the thing back in and took it to the shop for a repair. Turned out it was a long fencing staple.
But the strangest one was in Glasgow, driving along and 'bang', pretty explosive flat tyre.... Changed to the spare, and I could see this large and strangely shaped metal thing stuck in the tyre. Turned out that was actually what was left of a small Stilson wrench! The handle had managed to penetrate the tyre. I can only imagine it got stuck in a rut or hole in the road or something like that and had nowhere else to go. There was fully 4 or 5 inches of it inside the tyre, bent back by the wheel rim - and that was in a 30mph zone.
Hope you get sorted easily. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #732379 2nd Oct 2018 9:14am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Well, what happened??????? I cannot take the suspense!!!!! Cheers Don.
Post #732399 2nd Oct 2018 9:51am
Worth remembering that punctures are the complete opposite of stab wounds. One should be removed, one should not. Thumbs Up
Post #732416 2nd Oct 2018 10:40am
geobloke
Ha Tuesday morning roulette... place you bets folks... Round and around it goes when it punctures no-body knows... Rolling Eyes Rolling Eyes
Well here you go... No Pssssshhhhhttt but the tip of the screw looks mightily shiney, wonder what that has been rubbing against?!?!
The good news is that the "Spit Test" came back negative for bubbles, so take from that what you will... Rolling Eyes
Post #732417 2nd Oct 2018 10:48am
donmacn
Good news! Not such a bad start to the day after all. Donald
in the past..
Post #732419 2nd Oct 2018 11:11am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Good news, would also do a fairy liquid test to be sure.
Just had two nails in my VW Golf's tyre. Costco said they were too close to repair (but another shop might do it)
Given the cost of repairing two punctures is practically half the cost of a tyre, I just got a new tyre Big Cry
Post #732421 2nd Oct 2018 11:15am
That doesn't look long enough to penetrate deep enough.
BFG's have a lot of Ply's and banding in them, a lesser tyre would likely have gave you a puncture.
Unfortunately when I had issues it was a cut and not a hole, and you can bet it'll be the sidewall or outer tread shoulder and not th emiddle of the tread.
Although it sounds a bit Heath Robinson, I'd check for any leaks yet again to be sure.
If that is a positive outcome make sure it's thoroughly dry and I'd fill it with a tiny bit of black silicone.
Otherwise, come MOT time, even thought it's perfectly okay it might get probed and failed even though there is no problem with it.
They often don't grasp the concept that these tyre's are very very thick and have multiple wall reinforced treads and judge it by standard car tyre standards.
If the outcome of a second leak test works out I'd say a lucky escape. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #732426 2nd Oct 2018 11:29am
geobloke
Yes indeed good news. I will of course keep a very close eye on the tyre for many days to come. Good idea about the silicone...!
Not such a bad start to the day after all... what a relief!
Post #732434 2nd Oct 2018 11:58am
Balvaig
Don't know whether you can still buy it, but you used to be able to get the black rubber solution/glue that was used to seal the rubber plugs for DIY puncture repairs.
I would use this in preference to silicone as it should give a more robust seal to the hole.
Post #732438 2nd Oct 2018 12:26pm
^^^^ This would be even better of course. Thumbs Up ____\We|Will|Win/___
Post #732439 2nd Oct 2018 12:29pm
