Home > Maintenance & Modifications > Help needed with Towbar Setup
Page 2 of 3 <123>
DAZ110
That suits me just fine as I have a 2011 90 CSW N1 Thumbs Up
Post #731541 27th Sep 2018 6:01pm
X4SKP
Humm...I didn't know about Regulation 55 either
LRA has summarised it well I think , there is a two year window late 2010-2012 where
Type Approval isn't required (although probably in most cases worth installing).
There is a good overall summary for Towing Equipment, which includes this Type Approval
'correction' made in 2012, in a Data Sheet issued by the Camping and Caravanning Club.
https://www.campingandcaravanningclub.co.u...eet-29.pdf SKIP
Post #731617 28th Sep 2018 8:47am
leeds
Must admit I have not got my head around all the time scales and tax classes for type approved towing equipment.
There are differences between the published date of a directive and the date it comes into effect. Also there are legal differences between what is an EU directive and an EU law.
As far as I am aware the date of regulation 55 is 2012 and I think the effective date is sometime in 2015 but am willing to be corrected on the actual dates.
As an example the recent changes in the UK MOT in May this year was based on an EU directive of 2014/45/EU dated April 2014 so there was about a 4 year gap between date of act and date of implementation.
Why can't things been simpler and clearer when it comes to motoring law/regulations.
Brendan
Post #731623 28th Sep 2018 9:17am
X4SKP
Will this all be cleared up in the Brexit Deal being negotiated Question SKIP
Post #731627 28th Sep 2018 9:47am
The date that I've quoted above, 29th October 2012, is the implementation date, from which it became effective. Darren
Post #731646 28th Sep 2018 12:03pm
What do you think? Rolling with laughter
It is, I think, worth bearing in mind that the UK will probably want to continue selling British-built vehicles into the post-Brexit Europe, and therefore will undoubtedly have exactly the same C&U and Type Approval regulations as Europe.
It seems to me to be highly unlikely that common sense will prevail and abominations like DRLs and rear fog lights will suddenly become unnecessary. Sad
Post #731668 28th Sep 2018 2:46pm
The C&C Club document is interesting, and also explains why it is now impossible to buy new (and in many cases illegal to use) the old DB Shocklink:
campingandcaravanningclub.co.uk wrote:
Many years ago towbar manufacturer Dixon Bate produced the Shocklink coupling. It uses coil springs with rubber inserts to absorb any shocks transmitted through the towbar to the trailer. The coupling is primarily designed for use on 4x4s and other large vehicles fitted with leaf spring rear suspensions.
The Shocklink was only available for vehicles fitted with a Dixon-Bate adjustable height towbar. It can't be used with other type approved towbars unless the towbar has been granted type approval with the Shocklink in place . If you can still find one it can be fitted to cars registered before 1 August 1998 and motorhomes registered before 29 October 2012.
Post #731670 28th Sep 2018 3:17pm
leeds
Interesting comment BW which I find very difficult to believe about the Shocklink. The shocklink on the back of our white 90 has what appears to me to be a valid approval mark. Since it is approved I can not understand why the C & C club does not think it is road legal. Under their argument if you changed an approved towball for another towball from a different manufacturer then that would be illegal.
Yes the Shocklink was designed to work with the Dixon Bate towing equipment. Now the Dixon Bates brand was bought by Bradley Doublelock who were subsequently taken over by Al-ko who I understand has been bought out by some American venture capitalist. On Al-ko taking over BD I was told the factory was moving south to utilise surplus factory manufacturing capacity down south and closing the Yorkshire plant. They were going to trim the range of products and concentrate on the more profitable items. So the Shocklink went in the reorganisation nothing to do with them being illegal.
Today I was told by a big UK parts distribution unit that some multifunctional lights were not road legal in the UK despite them having full approval marks under the Vehicle harmonisation programme!
Brendan
Post #731761 28th Sep 2018 9:22pm
I think the issue is that the whole assembly has to be approved, rather than each component. It is not the Shocklink that is the problem, rather that the bracket to which is is attached has to be type approved with the Shocklink attached.
In other words you can't attach a type approved Shocklink to a type approved towbar unless the towbar has also been type approved with the Shocklink attached.
Post #731798 28th Sep 2018 10:59pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Wow, not like me to start a large debate Shocked Laughing
I'm lucky with my 2010 model that I fall outside the approval timeline.
Without replying to you all individually I'll summarise below my thoughts after reading the thread:
- I should probably keep the guard/detachable setup as it's a good bit of kit
- I will try to obtain some bolts and nuts to replace the pins to see if I can stop the rattle
- I will definitely look into the HD hinges, saves fitting the carrier although the downside is the weight is still on the door, though my door is good at the moment
- Depending on the above, I may need to extend the bike fitting back a bit
I still love the look of the NAS step bit I think it will end up all expensive and I may regret selling the guard etc. But we'll see!
Thank you all so much for the inspiration and ideas, it is always much appreciated Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #731803 28th Sep 2018 11:55pm
leeds
I am not sure that is correct BW. We have changed the tow ball on Land Rover supplied and fitted towing equipment (Dixon Bates) to an approved Alko tow ball. Was the LR fitted towing equipment tested and approved with the Alko tow ball?
Now the DB Shocklink has what appears to me to be an approval mark. The interesting thing is the country code ( IIRC E11 ) is not the current standard format for a country code. The current standard country code is an E + number in a circle. The country code on the Shocklink is inside a rectangle. Now what that means for the type approval I do not know.
Brendan
Post #731804 29th Sep 2018 12:09am
You have to wonder whether anyone at Al-Ko has the slightest clue how to run a business!
Despite Al-Ko taking over DB two years or more ago and discontinuing the Shocklink, the old DB website is still up and running, and advertising the (discontinued) Shocklink.
https://dixon-bate.co.uk/products/gb/100-shocklink
Of possible relevance is the following:
the late lamented Dixon Bate wrote:
Pre-August 1998 registrations: Shocklink Mark II can be fitted to the existing towbar using the adapter plate if the towbar has 4 coupling holes and that there is sufficient clearance around the bumper.
Eu Approved Vehicles August 1998 on: Only fit the adapter plate after first checking with the towbar manufacturer that doing so will not invalidate the towbars’ approval
The second paragraph is I think significant and suggests that the towbar must be tupe approved with the Shocklink, or possibly through the range of towball offsets that the Shocklink allows.
The article linked above also makes it clear that drop plates and spacers will also generally invalidate type approval.
What a minefield! I am glad my 2007 N1 Defender is outwith the regulations and I can still happily and legally mount my Shocklink on a drop plate in my 2" receiver.
Post #731870 29th Sep 2018 4:36pm
leeds
That is interesting BW. I agree with your comments about Al-ko but enough said on that subject!
I am glad that we use the LR towing equipment which comes from Dixon Bates (apart from our red 110 which predates all this!) so have no issue with use of the shock link.
As you say BW it is a minefield and it is a pity that these regulations are so complicated.
Ozzie do not worry that it has become a debate, this way we all learn a bit.
Brendan
Post #731894 29th Sep 2018 7:45pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I went through this with DB when I bought a shocklink from them, they asked for the information from the tow bar, which they confirmed was one of there's and supplied to Land Rover and not a "copy part" which had been fitted and it was okay to fit the Shocklink. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #732191 1st Oct 2018 2:16pm
X4SKP
Ok just to add to this, mine was MOT'ed yesterday (... Thumbs Up 24th Pass in a row for Defender ownership)
anyway, on being told all was ok again, and the pleasing, if you ever sell it can we have first refusal, I raised the
issue of the Towing Equipment fitted, (brave I know Shocked ) they did know about Regulation 55, and did also know
about the 2010-2012 N1 Window for non-Type Approved Kit, Custom or otherwise.
I'm OK but I could not do what I have done to a Defender registered after 29th October 2012.
There are a very good family run Garage, the Dad and his Son also said sometimes it is difficult to tell now as often the Type Approval stickers are missing for a long time the need to see a Type Approval Sticker was not part of the MOT, I took from this that maybe now it is?
Mine is a combination of both Type Approved and Custom Kit, but it has all been resprayed twice in the last 4 years, and has no markings, (I think I read somewhere this is an issue in some European Countries, and or at Borders).
They also said that from 27th April 2009 Tow bars and their attachment to the vehicle become part of the MOT,
it is very likely that not all MOT Centres are up to date with all directives issued, apparently there has been quite a lot,
like most things you don't know what you don't know.
This link to a 2012 MOT Test Manual, makes no mention of the 55 Regulations
http://www.ukmot.com/manual/6.6/Towbars#MOT SKIP
Post #733089 5th Oct 2018 1:15pm
Page 2 of 3 <123>
