![]() | Home > Puma (Tdci) > Front passenger seat belts |
There are a few reputable suppliers on eBay of seatbelts for much less than your quoted price. Advance Factors (site sponsore) sell them at £60 and I can’t fault them, quick delivery and great to deal with
![]() Might be worth investing in these: https://www.thexmod.com/item_detail.asp?id...lt_8510403 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Thanks tha'ts more affordable - will check out AF
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
I have the same issue with mine, on the passenger side as well.
Although no problem with MOT as its only marking to the belt. I think it's because of it being on the left side when the passenger gets out they are more likely to slide it around to the side. Drivers side more likely to hook yourself on the door latch instead. ![]() ![]() ____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 242 ![]() ![]() |
Same prob here! I’ve swapped both my belts out for new red ones (cheaper and snazzy!), put on the x-trouser door strikers, sprayed the belts with silicon spray and still have the same problem😞
For me it seems to originate with the belts folding slightly as they retract (due to angle to belt from pillar), the folded belt then fills the reel up before all the belt is retracted, so more belt is left out and this gets caught in the door. SO I’ve just ordered two of these sleeves, I’m going to put them on the belt immediately above the reel so that the belt always feeds in flat. Will update if this helps!! https://m.ebay.co.uk/itm/Genuine-Land-Rove...SwfphadL35 |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Unbolt the passenger seat and take it back for MOT without the seat. ![]() Gives you and excuse to make your passenger walk too, they should take more care of your car. ![]() |
Passenger doesn't like travelling in there anyway - says it's a farm vehicle
I have ordered the Wolf plastic thing that moves the belt forward a bit - let's see Got the belt from Exmoor Trim in the end - but available from LR parts for circa £40 |
The Exmooor trim seatbelts fit fine. Small issue but the inertia reel part is slightly too large for the LR cover to go back on. But looks fine without the cover.
The cover has some plastic screws holding it in place - not sure what screw head type they are - look like phillips but I just seemed to destroy the head - had to make a slot with a carpet knife and use a standard slotted screwdriver to remove the cover. I didn't replace the bit the buckle goes into - the one provided is on a long stalk which is quite different from what is already there. |
