Home > V8 > Alternative to LT95 box
peterl
1987 Defender 90 300 Tdi HT Epsom Green
The plan was to replace the 4 speed with an auto with the v8 but am having second thoughts and think I will stick with the manual box.
Which is the best replacement, the R380 or LT85?
Will they fit onto the mounting points of the old 4 speed LT95 or will I need to modify.
Any opinions / guidance would be appreciated.
Post #699248 7th Apr 2018 8:02pm
JeremyJ
I’ve gone off the LT85, mine (a recon box) is really notchy and no good at being rushed.
I still want to auto my station wagon this summer, if I do the LT85 will be available.
Have you sorted an engine for her yet?
Post #699257 7th Apr 2018 8:16pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
The LT85 in mine is quite agricultural but after driving Series Land Rovers it’s not that bad at all IMO. Smile
Post #699306 7th Apr 2018 10:40pm
Hufflepuff
I'd quite like to know the answers to your questions too Peterl. I'm looking to ditch the LT85 in mine for an R380, primarily for the quieter running and less agricultural feel. I assume the gearbox mounts are universally positioned, as I have not heard of anyone moving those mounts? 2005 Td5 90 XS
1989 V8 110 CSW
Post #699312 8th Apr 2018 12:36am
In terms of which is the better box, it's the R380. The LT85 was strong in its' day but the later 'L' suffix R380 is stronger and is also much nicer to use. Darren
Post #699320 8th Apr 2018 7:07am
defender9
I would agree with the above comment but I’ll keep my original LT85 as my 90 was built with it and it’s not an everyday vehicle.
Post #699330 8th Apr 2018 9:23am
peterl
Jeremy, have got a 4.6 going in, just sorting out a gearbox. I have a 4 speed auto which I could use but preferring the manual route. R380 is the option but I need a v8 belhousing and they are rare....
May do a deal for my auto , it’s full recon and done approx 100 miles.
Pm me if you are interested.
Pete
Post #699427 8th Apr 2018 6:12pm
oneten110
I replaced the LT 95 box in mine with the R380. You will also need the LT 230 transfer box and a different front prop shaft. Not to mention seat box, tunnel and floor plates.
It was 20 years ago when I did the switch but I have recollections of having to change the gearbox mounting brackets on the chassis as well, a simple check of the parts list will show if this is the case. They are not a big job to replace because they are bolted to the chassis
Post #717243 11th Jul 2018 11:22pm
peterl
Gone auto, be out of the workshop soon.....
Post #730501 22nd Sep 2018 2:58pm
peterl
Looking to go back to manual, a four speed auto doesn't feel right, even if it does scare the sh** out of me when booted.
Pete
Post #790555 4th Sep 2019 7:06pm
