|  | Home > Maintenance & Modifications > Mirror arm replacement or whole unit ? |
| johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006      |
 Morning all
 Both my wing mirrors look like this   Click image to enlarge Is it Ok to just replace the arm like so... https://www.famousfour.co.uk/new_parts/ff_part?part=9141 Or is it better to replace the whole unit? JD 2008 TDCi 2.4 XS CSW | ||
|  17th Sep 2018 9:10am |
| camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3418    | The whole assembly (mirror and arm) is only £11.29 new from paddocks.
 https://www.paddockspares.com/mtc5217-door...-type.html | ||
|  17th Sep 2018 9:20am |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897      | If you do any towing get Wolf replacements.   | ||
|  17th Sep 2018 10:44am |
| Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309      | Keep the original mirrors if you can or install the same ones as you currently have. I think the geometry of the different makes is different. A couple of months ago I replaced the original Britax mirrors by a Britpart set that I got with a box of parts. Should have known better: the very same evening I was convinced that I had plenty of space behind the 110 when parking, but nevertheless I heard some very unexpected and expensive sounds behind me. I must have seriously misjuged the distance to the car behind me.
 Also, the BP mirrors were continuously flapping in the wind when driving on the motorway, very annoying. Regards, Joris | ||
|  17th Sep 2018 1:06pm |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720      |
 Or just hinge the standard ones forward like it says in the handbook, fitting the long ones makes them more prone to getting hit. | ||
|  17th Sep 2018 2:26pm |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946      | If you have very deep pockets you could go swanky and get the Defender Upgrades heated and puddle light arms      James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers | ||
|  17th Sep 2018 2:47pm |
| Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514      | ^^^^^ very deep pockets indeed,   Cogito ergo sum | ||
|  17th Sep 2018 3:13pm |
| lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343      | If I can give any advice, it would be to stay clear of the lower cost replacement arms and fit the OE versions. (I think the original arm was made by Britax as well as the mirror).
 I fitted a pair of cheap arms only a year or so ago and already the paint has started to flake off in the usual places. Also the spring assembly that holds the arm in place is much weaker than the LR original and I also think the ball end is a slightly smaller diameter. As a result, unless the clamps on the mirrors are tightened to within a fraction of shearing, the mirrors start to move at speed. And at tick over, both mirrors now tend to vibrate, which I put down to the weaker spring in the arm. In my experience with the cheap arms it is definitely a case of getting what you pay for. That being said, the paint on the originals doesn't seem to stay in place for too long either  | ||
|  17th Sep 2018 5:25pm |
| v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195      | go ome not many pounds over aftermarket.
 and most important they dont flap about at speed. 110 xs s/wagon s3 swb soft top | ||
|  17th Sep 2018 6:17pm |
 Yep, whole thing is made by Britax. | ||
|  17th Sep 2018 8:05pm |
| Jimmy B Member Since: 11 Nov 2017 Location: Cumbria Posts: 51    | The cheap ones always end up looking at the ground no matter how much you tighten them up | ||
|  17th Sep 2018 8:21pm |
| johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006      | Time to reflect on my purchase I feel.......    JD 2008 TDCi 2.4 XS CSW | ||
|  17th Sep 2018 8:29pm |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441    |
 Mirrors flapping about at speed.... Come on we are talking about Defenders here aren't we?  | ||
|  17th Sep 2018 8:35pm |
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270      | you can get a cheap one for now and paint strip/rub down the original ones then repaint for when the cheap ones corrode. 1953 80"
 1987 mini city e 2011 90" | ||
|  18th Sep 2018 7:10pm |
| Posting Rules
