Home > Maintenance & Modifications > Mirror arm replacement or whole unit ?
johnnyd
Morning all
Both my wing mirrors look like this
Is it Ok to just replace the arm like so...
https://www.famousfour.co.uk/new_parts/ff_part?part=9141
Or is it better to replace the whole unit?
JD 2008 TDCi 2.4 XS CSW
Post #729462 17th Sep 2018 10:10am
VVS210
Have a look at the screws holding the mirror to the arm - if the arm is that corroded then I'd guess the screws & clamp are also properly corroded, mine were. Just get a pair of take off arms with mirrors, cost me about £15 each & the benefit is nice dark black mirror backs not faded grey ones too Thumbs Up
Post #729463 17th Sep 2018 10:14am
camelman
The whole assembly (mirror and arm) is only £11.29 new from paddocks.
https://www.paddockspares.com/mtc5217-door...-type.html
Post #729466 17th Sep 2018 10:20am
Laurie
If you do any towing get Wolf replacements.
Post #729483 17th Sep 2018 11:44am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Keep the original mirrors if you can or install the same ones as you currently have. I think the geometry of the different makes is different. A couple of months ago I replaced the original Britax mirrors by a Britpart set that I got with a box of parts. Should have known better: the very same evening I was convinced that I had plenty of space behind the 110 when parking, but nevertheless I heard some very unexpected and expensive sounds behind me. I must have seriously misjuged the distance to the car behind me.
Also, the BP mirrors were continuously flapping in the wind when driving on the motorway, very annoying.
Regards,
Joris
Post #729514 17th Sep 2018 2:06pm
zsd-puma
Or just hinge the standard ones forward like it says in the handbook, fitting the long ones makes them more prone to getting hit.
Post #729530 17th Sep 2018 3:26pm
JOW240725
If you have very deep pockets you could go swanky and get the Defender Upgrades heated and puddle light arms Whistle
 James
Instagram @suffolk_rovers
Post #729537 17th Sep 2018 3:47pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
^^^^^ very deep pockets indeed, Shocked Cogito ergo sum
Post #729544 17th Sep 2018 4:13pm
lohr500
If I can give any advice, it would be to stay clear of the lower cost replacement arms and fit the OE versions. (I think the original arm was made by Britax as well as the mirror).
I fitted a pair of cheap arms only a year or so ago and already the paint has started to flake off in the usual places.
Also the spring assembly that holds the arm in place is much weaker than the LR original and I also think the ball end is a slightly smaller diameter.
As a result, unless the clamps on the mirrors are tightened to within a fraction of shearing, the mirrors start to move at speed.
And at tick over, both mirrors now tend to vibrate, which I put down to the weaker spring in the arm.
In my experience with the cheap arms it is definitely a case of getting what you pay for.
That being said, the paint on the originals doesn't seem to stay in place for too long either Sad
Post #729566 17th Sep 2018 6:25pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
go ome not many pounds over aftermarket.
and most important they dont flap about at speed. 110 xs s/wagon
s3 swb soft top
Post #729581 17th Sep 2018 7:17pm
zsd-puma
Yep, whole thing is made by Britax.
Post #729626 17th Sep 2018 9:05pm
Jimmy B
The cheap ones always end up looking at the ground no matter how much you tighten them up
Post #729633 17th Sep 2018 9:21pm
johnnyd
Time to reflect on my purchase I feel....... Rolling with laughter
Post #729638 17th Sep 2018 9:29pm
williamthedog
Mirrors flapping about at speed.... Come on we are talking about Defenders here aren't we? Rolling with laughter
Post #729643 17th Sep 2018 9:35pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
you can get a cheap one for now and paint strip/rub down the original ones then repaint for when the cheap ones corrode. 1953 80"
1987 mini city e
2011 90"
Post #729813 18th Sep 2018 8:10pm
