Home > Puma (Tdci) > First Service & Warranty Tips
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
I am approaching the first service for my 110 and I want to address any likely warranty work at the same time.
I am going to push for the rust on the tow bar to be dealt with as an example, the dealer has already said they believe LR will replace it. Also a few rusty screws. I'm also pointing them towards the rear step.
Anyone got any tips or pointers of other things to be aware of or things worth getting the dealer to check whilst it is with them?
Luckily I seem to have a proactive dealer.
I intend to make good use of the warranty.
Thanks in advance! Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #72635 25th May 2011 12:06am
BigMike
numberplate brackets, check for rust.
P022 safety recall
look for any body alignment issues, especially cappings and foam seals where roof meets body on sides and rear
check all rivets on the body are still present
any water ingress passenger or drivers footwell
the first service is really just an oil change and you can have warranty work done whenever an issue crops up so I'd say just give it a good examination after youve cleaned it. also if you know what youre looking at on the underside, get it on a ramp at a friendly indy and see if there is anything to look at like transfer box seal, diff seals, anti roll bar mounts, drag links and the ends, track rod and the ends etc, exhaust mounts, springs, shock mounts and shocks generally.
Post #72637 25th May 2011 12:13am
Thanks Mike! Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #72820 25th May 2011 11:48pm
BigMike
I didnt mean number plate brackets, i meant mud flap brackets. not sure what happened there Laughing
Post #72821 25th May 2011 11:50pm
Laughing Bizarrely I did realise what you meant and actually mine are shot with rust.
Thanks again! Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #72823 26th May 2011 12:05am
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mine is in Hillendale for Parking Brake recall on Saturday
I am also getting them to look at Head Lamp problems. After using main beam head lamps flicker on and off for a bit this can be fun late at night on unlit roads (Relay or switch I suspect) worth checking yours.
My Mud flaps brackets are also rusty - Will look at them also
Previously we have had heat shields resecured and software upgrade on ECU - These removed the "bag of hammers" sound at 2300 to 2600 rpm
However as far as I know my number plate is fine mainly because I have moved it myself since my tail flap has been removed for camper to fit on the back Laughing 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #72825 26th May 2011 12:13am
Happyoldgit
Check the headlamp bezels aren't turning to dust. Steve.
http://forums.lr4x4.com
Post #72851 26th May 2011 8:20am
RFT wrote:
... After using main beam head lamps flicker on and off for a bit this can be fun late at night on unlit roads (Relay or switch I suspect) worth checking yours....
The other common cause of bizarre headlight behaviour (including them going off completely at inconvenient moments) is either the light switch or (more commonly) the dipswitch overheating and partially melting allowing the contacts to move.
This generally gets progressively worse since as the contacts become more misaligned they get hotter.
Post #72865 26th May 2011 9:42am
RFT will you let me know how you get on with Hillendale as I am thinking of taking mine there also for service and recall. I'm working on the theory that they have plenty of Defender experience because of the rural location. It would be good to hear about your experience especially with the recall thoroughness..?? Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #72959 26th May 2011 8:23pm
RFT
I'll let you know after the weekend, they have been excellent to date.
I'll test it out around Lancs / Yorks border hoping to get up to Malham over the weekend, staying with M-in-Law in Colne
Richard 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #72962 26th May 2011 8:37pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Just thought I'd pipe in with my Hillendale experiences...
Can't fault them at all, despite Big Black throwing tantrums and me spending quite a lot of time there a few months back they've always been professional and friendly, I've always been provided with a courtesy car and always got mine back valeted. Plus they're only 5 minutes away from me! Win win! Thumbs Up
Post #72998 27th May 2011 12:11am
RFT
Hillendale once again were excellent.
Recall all sorted, no oil leak so no need to change pads.
Headlight problem found to be relay that was hot, switch contacts all ok.
The staff are polite, efficient, knowledgeable and the coffee machine makes a fine coffee.
They washed the 130 and fitted a spare wheel cover.
A very satisfied customer, worth the 70mile drive.
Post #73191 28th May 2011 12:25pm
Thanks for the update RFT - good to hear that Hillendale did a good job.
BTW - great photos - love the Camper! Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #73317 29th May 2011 11:57am
