![]() | Home > Puma (Tdci) > Excessive Oil Consumption |
| Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223
Hi All
I was told this morning by one of my neighbours that he is currently using one litre of oil a week in his 2014, (warranty expired January),Puma 110. As the vehicle has only done 38000 miles would someone be able to suggest a starting point for investigating this. There does not appear to be any external visible signs of any leak. Thanks very much for your help Swine 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Any ideas?
Thanks 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
| WRFrance Member Since: 14 Nov 2015 Location: Deep in the West Posts: 16
Hi there,
Have a look at this thread. Some pointers in there. Check engine blowby first by pinchin the engine breather hose, it should take a while until noticeable pressure builds up. If pressure builds up very fast, blowby is too high. http://www.defender2.net/forum/topic52237.html |
Thanks for that information. Plenty to be going on with there.
Kind regards Swine 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
In this case tell him to check the injectors copper seals...... cheap to solve in this case... If the seal is leaking, engine eats oil by suction from the camshaft room. http://www.defender2.net/forum/topic55156.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461
Using the wrong oil seriously ruins the engine.
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Got a 2011 2.4, granted it only does about 4,000 a year but it has never used any oil between services.
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357
Nor did mine.
In fact it has been pretty much faultless. Until now... |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
on the motorway trips did you push on a bit? turbo oil seals? Cheers
Thanks for the reply
My motorway driving was definitely harder than my usual pootle to/from work, engine was no doubt working harder, but I wasn't hammering it. I'll check that out. |
I'm out and about and need advice.
I need to top up my 2010 2.4. Is Castrol EDGE Professional C1 5W-30 ok? |
Hi , Sorry for the delay in the response . My neighbour has only just got back to me.
Injector seals turned out to be the culprit. All fixed at back to normal now. Thanks for your help 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Good to know. Or at least a good place to start. Injector seals and turbo oil seals.
| Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81
I would strongy suggest your neighbour, after changing the cupper (sold for the price of gold) injector seals, also disassembles the oil sump to have a quick check for carbon particles, especially in the oil strainer! If there was carbon 'hanging' on the injector there will be carbon inside the engine.
Click image to enlarge |
