Home > Puma (Tdci) > Excessive Oil Consumption
Swine&Small
Hi All
I was told this morning by one of my neighbours that he is currently using one litre of oil a week in his 2014, (warranty expired January),Puma 110. As the vehicle has only done 38000 miles would someone be able to suggest a starting point for investigating this. There does not appear to be any external visible signs of any leak.
Thanks very much for your help Big Cry
Swine 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #631298 14th Jun 2017 12:55pm
Swine&Small
Any ideas?
Thanks 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #631670 15th Jun 2017 7:58pm
WRFrance
Germany 2012 Defender 90 Puma 2.2 PU Keswick Green
Hi there,
Have a look at this thread. Some pointers in there.
Check engine blowby first by pinchin the engine breather hose, it should take a while until noticeable pressure builds up. If pressure builds up very fast, blowby is too high.
http://www.defender2.net/forum/topic52237.html
Post #631677 15th Jun 2017 8:16pm
Swine&Small
Thanks for that information. Plenty to be going on with there.
Kind regards
Swine Thumbs Up 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #631709 15th Jun 2017 10:11pm
dgardel
Italy
WRFrance wrote:
Hi there,
In this case tell him to check the injectors copper seals...... cheap to solve in this case...
If the seal is leaking, engine eats oil by suction from the camshaft room.
http://www.defender2.net/forum/topic55156.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #631754 16th Jun 2017 6:35am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Using the wrong oil seriously ruins the engine.
Post #631755 16th Jun 2017 6:41am
Zed
Bumping this thread as I am experiencing the same issue.
About 3 weeks ago the oil warning light came on so I topped up with approximately 4 litres. Checked daily and all was well, short trips only, then dipstick went from full to half after 2 x 250 mile motorway journeys.
No visible leaks or smoke and engine seems to be running fine.
Any ideas?
@Swine&Small. Did your mate get to the bottom of this?
Edit: It's a 2010, 2.4 , 75000 miles
Post #726639 1st Sep 2018 2:44pm
williamthedog
Got a 2011 2.4, granted it only does about 4,000 a year but it has never used any oil between services.
Post #726668 1st Sep 2018 4:50pm
Zed
Nor did mine.
In fact it has been pretty much faultless.
Until now...
Post #726673 1st Sep 2018 5:42pm
jst
on the motorway trips did you push on a bit? turbo oil seals? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #726700 1st Sep 2018 9:10pm
Zed
Thanks for the reply
My motorway driving was definitely harder than my usual pootle to/from work, engine was no doubt working harder, but I wasn't hammering it. I'll check that out.
Post #726716 1st Sep 2018 10:20pm
Zed
I'm out and about and need advice.
I need to top up my 2010 2.4.
Is Castrol EDGE Professional C1 5W-30 ok?
Post #726743 2nd Sep 2018 11:02am
Swine&Small
Hi , Sorry for the delay in the response . My neighbour has only just got back to me.
Injector seals turned out to be the culprit.
All fixed at back to normal now.
Thanks for your help Thumbs Up Thumbs Up 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #726755 2nd Sep 2018 1:24pm
Zed
Good to know. Or at least a good place to start. Injector seals and turbo oil seals.
Post #726756 2nd Sep 2018 1:38pm
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
I would strongy suggest your neighbour, after changing the cupper (sold for the price of gold) injector seals, also disassembles the oil sump to have a quick check for carbon particles, especially in the oil strainer! If there was carbon 'hanging' on the injector there will be carbon inside the engine.
Post #726949 3rd Sep 2018 1:03pm
