![]() | Home > Puma (Tdci) > Wipers have stopped at half way |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
It could be the park switch.
But first lube the spindles and give the arms a little push whilst switched on ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Probably the spindles as said above, if you're lucky you might be able to oil them to get them working. If not get ready for cursing.
Eyezy Member Since: 07 Jul 2017 Location: Auckland Posts: 4 ![]() ![]() ![]() |
Outstanding ! - A couple of squirts of WD40 and we are all set to enjoy another sunny day in Auckland
Thanx ![]() |
![]() ![]() Use a bit of s longer lasting oil in there too shortly, as the WD40 will dry up but is good for freeing them up. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I use acf 50 on mine. A few drops every couple of months and you should be ok
Same here now too.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Will do - Thanx for the tip
GrouseII Member Since: 29 Dec 2017 Location: Bucks Posts: 37 ![]() ![]() ![]() |
I had the same issue and the relief was great when good ol WD40 solved it ... BUT, I continued to repeat the process of running the wipers (pulled away from screen) and squirting liberally for a few minutes on the splines for at least 4 days to make sure the oil got down good and deep and did it s job. Each time some rusty residue came out of the splines.
Besides, i love the smell of WD40 ![]() |
