Home > Puma (Tdci) > Wipers have stopped at half way
Eyezy
New Zealand 2008 Defender 90 Puma 2.4 HT Alaska White
The wipers have stopped half way up the screen, I can hear what I think is a relay clicking once when they are switched on and when switched to intermittent I think I can hear a relay clicking every few seconds. I can't hear the wiper motor running. The washers also work when the button is pressed. Can I assume that means the switch is OK, the fuse appears to be OK. Would i be able to hear the wiper motor running if it's the cable drive? Does this point to a motor fault ? It's a 2008 90 that's done 100k kms. Thanx
Post #726696 1st Sep 2018 8:50pm
It could be the park switch.
But first lube the spindles and give the arms a little push whilst switched on ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #726702 1st Sep 2018 9:19pm
williamthedog
Probably the spindles as said above, if you're lucky you might be able to oil them to get them working. If not get ready for cursing. Confused
Post #726718 1st Sep 2018 10:23pm
Eyezy
Outstanding ! - A couple of squirts of WD40 and we are all set to enjoy another sunny day in Auckland
Thanx Bow down
Post #726721 1st Sep 2018 11:37pm
Thumbs Up Thumbs Up
Use a bit of s longer lasting oil in there too shortly, as the WD40 will dry up but is good for freeing them up. ____\We|Will|Win/___
Post #726758 2nd Sep 2018 1:43pm
williamthedog
I use acf 50 on mine. A few drops every couple of months and you should be ok Thumbs Up
Post #726768 2nd Sep 2018 2:56pm
Same here now too. Thumbs Up ____\We|Will|Win/___
Post #726783 2nd Sep 2018 4:18pm
Eyezy
Will do - Thanx for the tip
Post #726790 2nd Sep 2018 4:42pm
GrouseII
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
I had the same issue and the relief was great when good ol WD40 solved it ... BUT, I continued to repeat the process of running the wipers (pulled away from screen) and squirting liberally for a few minutes on the splines for at least 4 days to make sure the oil got down good and deep and did it s job. Each time some rusty residue came out of the splines.
Besides, i love the smell of WD40 Very Happy
Post #727529 6th Sep 2018 12:26pm
