![]() | Home > Maintenance & Modifications > Self-tapping screws - hole too big |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Which lights?
If you mean the round ones (indicators, brake, side lights etc) then they either had a plastic plug (fits in a square hole) which the screws went into, like a rawlplug. Or the earlier ones had a small captive spire nut clipped over the panel hole and the screws went into these - these often rust and fall off when you remove old screws. I'm not sure when Rover changed the fixing method. |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835 ![]() ![]() ![]() |
Spire clips may help
https://www.ebay.co.uk/i/192586749514?chn=ps&var=492746282041 ![]() (zsd-puma beat me to it)! |
jimmythomson Member Since: 18 Jul 2017 Location: Norfolk, UK Posts: 46 ![]() ![]() |
Sorry, should have said that I'm referring to the round lights. See below:
A photo to show the context: ![]() Click image to enlarge The screw here just passed straight through the hole without much effort: ![]() Click image to enlarge I suspect those U nuts may well be what I need. Thanks, Jimmy. |
it probably had the spire clips originally, but looks like it's been repaired/repainted at some point, they probably got lost/disintegrated when that was done.
https://www.landroverworkshop.com/diagrams...or_52867#6
AK606021L - SPRING NUT U TYPE - DEFENDER |
Brilliant! Thanks very much. I'll get some of those ordered.
Jimmy. |
Another quick light related question. This time it's the side repeaters. I should probably mention that I'm fitting this kit: eBay Item No. 361934176052
The connection for the side repeaters just doesn't feel tight. Has anyone fitted this kit from 'boltonbits'? The connection goes in as you can see from the photo, but I don't think it'll be too long before it's working itself lose. Am I missing a trick? Should I just wrap it in electrical tape? Photos for reference.... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Self amalgamating tape is your friend here
Either self amalgamating tape;
https://www.screwfix.com/p/self-amalgamati...tid=416546 Or you can get heat shrink that'll fit over it. |
Thanks, guys. I've got some of that on order from Screwfix. Will pick up tomorrow and crack on
The hole in your wing looks the wrong shape for those side repeaters Ray
Ray - I thought so too when I first saw them, but they're designed to fit as per the smaller original rectangular ones. I haven't actually put them in yet, but they look like they're going to be okay from a visual inspection.
Ray - just checked and they fit in nicely.
Excellent
![]() My build thread http://www.defender2.net/forum/topic17615.html |
