Home > 130 > 130 rear arches
fatboyron
130 rear arches
Just a quick question, I made a couple of threads about this.
Do I need a set of front arches from a 110 or was it the rear arches I would need?
And what size rivets should I use?
Many thanks
Ronald
Post #725300 24th Aug 2018 8:24pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
I think opinions on this vary, but IIRC I have 110 fronts on mine, reversed, and attached using 14 mm rivets. I used a cutting disk on an angle grinder to cut them back a bit (using tape as a guide), then sanded for a smooth finish.
 Defender 130 HCPU Td5 MY2000
Post #725500 26th Aug 2018 6:18pm
AndrewS
I've done a few, use standard rears. They are not quite the correct shape however when you fit them if you warm them up with something like a space heater this will help. Use molegrips to hold the arch in place whilst fitting. I use 16mm rivets.
Take a look in my gallery's.
 130's have feeling's as well you know Smile
Post #725541 26th Aug 2018 9:07pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
use a heat gun and be patient.
i used normal 110 rear arches and instead of rivets i used threaded nutserts
Post #725639 27th Aug 2018 2:36pm
fatboyron
Thank you all for your replies.
I've ordered set of rears and rivets and will have a go at the weekend, I shall put some pictures up when I'm done.
Ronald
Post #725711 27th Aug 2018 9:02pm
fatboyron
Finally got around to fitting my rear arches. Got a nice picture today on the way to St Michael's Mount
Post #731685 28th Sep 2018 4:53pm
Naf
Wider britpart arches
up front
Post #731699 28th Sep 2018 5:51pm
fatboyron
Naf what size type do you have. I'm running on 235's
Post #731702 28th Sep 2018 6:15pm
Naf
Wheels are 20x9 with an et10 am also runnin a 30mm spacer
Tires are 305/50r20 nitto grapplers
Post #731709 28th Sep 2018 6:41pm
saroshadil
United States 1999 Defender 130 Td5 HCPU Alpine White
These are my favorite. Can you please post some more photos!
Post #764554 20th Mar 2019 10:29pm
RoadForce
Thanks! I will try to (remember to) take some more and post them here. Defender 130 HCPU Td5 MY2000
Post #764632 21st Mar 2019 10:52am
RoadForce
Here ya go!
Stock suspension and 285x75r16...
Post #764707 21st Mar 2019 7:36pm
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
