![]() | Home > 130 > 130 rear arches |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 349 ![]() ![]() ![]() |
I think opinions on this vary, but IIRC I have 110 fronts on mine, reversed, and attached using 14 mm rivets. I used a cutting disk on an angle grinder to cut them back a bit (using tape as a guide), then sanded for a smooth finish.
![]() Click image to enlarge Defender 130 HCPU Td5 MY2000 |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
I've done a few, use standard rears. They are not quite the correct shape however when you fit them if you warm them up with something like a space heater this will help. Use molegrips to hold the arch in place whilst fitting. I use 16mm rivets.
Take a look in my gallery's. ![]() Click image to enlarge ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
use a heat gun and be patient.
i used normal 110 rear arches and instead of rivets i used threaded nutserts ![]() |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 ![]() ![]() |
Thank you all for your replies.
I've ordered set of rears and rivets and will have a go at the weekend, I shall put some pictures up when I'm done. Ronald |
![]() Click image to enlarge Finally got around to fitting my rear arches. Got a nice picture today on the way to St Michael's Mount |
Wider britpart arches
![]() Click image to enlarge ![]() Click image to enlarge up front |
Naf what size type do you have. I'm running on 235's
Wheels are 20x9 with an et10 am also runnin a 30mm spacer
Tires are 305/50r20 nitto grapplers |
saroshadil Member Since: 29 Nov 2018 Location: Detroit, Michigan Posts: 3 ![]() ![]() ![]() |
These are my favorite. Can you please post some more photos!
Thanks! I will try to (remember to) take some more and post them here. Defender 130 HCPU Td5 MY2000
Here ya go!
Stock suspension and 285x75r16... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Defender 130 HCPU Td5 MY2000 |
