Home > My Defender > Grafty's Td5 90
Page 71 of 124 <123 ... 707172 ... 122123124>
L110CDL
^^^ Rolling Eyes Laughing Clayton.
Keeper.
Post #723689 15th Aug 2018 10:51pm
grafty99
FINALLY the locking tools have arrived. So this evening I popped the head off. I foolishly assumed that being a 15p my engine would have metal dowels. Turns out that they were plastic. (Early 15p) Rolling Eyes
So a bit of head float and pistons in cyl 2, 3 and 4 have interfaced with the valves. Nothing major but there is a tiny mark in those 3 pistons Shocked
Anyway the bores look great (can still see the honing marks) and have no lip.
Looking at the gasket there are no obvious signs of gasket failure but there might not be if there has been head float.
Tomorrow I'm going to be enquiring about having the head pressure tested and hopefully start getting things back together by the and of the week Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #724470 20th Aug 2018 8:58pm
barbel jim
Fingers crossed George Thumbs Up worth splitting for peace of mind that all the tweaks haven't been detrimental. Trigger will be happy Mr. Green
Post #724477 20th Aug 2018 9:22pm
grafty99
Yeah absolutely, everything is looking very good, 130k miles on plastic dowels at near double factory output isn't too shabby. Shows that I drive it like Miss Daisy Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #724497 20th Aug 2018 10:09pm
Procta
good stuff grafty Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #724507 20th Aug 2018 11:43pm
grafty99
Well, things are not as dandy as they first appeared Crying or Very sad
Today, I decided to clean up the head in preparation for having it pressure tested. In removing the carbon and stuck gasket material the true extent of the problem showed itself. The head float has been so extreme and (it would appear) has been going on for quite some time as the head is actually burred around cyl 3, 4 and 5 Shocked
To make matters worse, my local landrover dealer has sent out the wrong parts Big Cry
So I'm going to be replacing with an AMC head. Hopefully I can get it all done before my trip to the Nürburg Ring in September Shocked
1990 Vogue SE
Post #724937 22nd Aug 2018 9:59pm
L110CDL
At least you have finally found the problem and hopefully you can get it all done before you have your trip Wink Clayton.
Keeper.
Post #724941 22nd Aug 2018 10:09pm
Procta
At least that's made the decision for you, yeah its a pain when that happens with the wrong parts. I was given the wrong locking tool for the bottom end. So when it came to doing the timing belt, things were not right.
What has caused the head float? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #724964 22nd Aug 2018 11:42pm
grafty99
Plastic head dowels Procta. Very common for them to break, allowing the head to move and cause the above damage. Brilliant idea from landrover Rolling Eyes 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #724975 23rd Aug 2018 6:56am
barbel jim
Are you sure Rolling with laughter Rolling with laughter
Post #724998 23rd Aug 2018 10:19am
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
George,
hope you get this 'challenge', never a problem!, resolved soon.
Everything crossed for you,#Cheers,
Simon Thumbs Up
Post #724999 23rd Aug 2018 10:23am
barbel jim
The early (10p) engines were renown for head gaskets running standard. The 15P (circa 2002)engines should have metal dowels to stop the head moving around, should it lift. Unfortunately, and not surprising the Lanrdover employee used the whats at hand approach when building Georges engine Rolling Eyes coupled with his extras Laughing its proved costly. However with the need for another Head, another modification can be made
Post #725000 23rd Aug 2018 10:28am
grafty99
New AMC head ordered from Wards Engineering, my valve gear will be going in and I'm having solid metal dowels turned to make sure this never happens again!
They have assured me that it will be with me before the end of next week. Looks like the Nürburg Ring is still on Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725007 23rd Aug 2018 10:58am
barbel jim
Thought about Low comp pistons ??I know you can get uprated head bolts but not cheap Big Cry
Post #725016 23rd Aug 2018 11:40am
Procta
I am sure the k series engine had a similar problem with the dowels. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #725023 23rd Aug 2018 1:03pm
