Home > Td5 > Adjusting difflock lever
excossack
After the new transfer case was fitted, i noticed now and then the difflock light would flicker on the dash, this evening I set about adjusting the lever.
After some fiddling I noticed that when trying to engage difflock the U shaped link between the end of the lever and the selector on the TC looked like it was fouling on the bolt head on the transfer case.
I think what I need to do, is wind the pivot point bolt, further in towards the gearbox so when selecting difflock the lever will give more room for the U shaped link to move and not foul on the bolt head?.?
That make sense? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #723292 13th Aug 2018 9:12pm
jst
or remove the small u bent connecting rod and fit a washer so the tail doesnt hit the bolt head? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #723294 13th Aug 2018 9:14pm
excossack
I did think of that as well, but wasn't sure how the clip came off? 1999 Defender TD5 110
Regards
John M0VAZ
Post #723310 13th Aug 2018 10:01pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Lift the curved up edge and slide the locking clip off. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #723322 13th Aug 2018 10:27pm
dorsetsmith
Post #723361 14th Aug 2018 7:44am
excossack
Cheers all. I have adjusted the rod circle (12) but its the bottom circled bit that is catching on the bolt on the transfer case
Regards
John M0VAZ
Post #723363 14th Aug 2018 8:06am
dorsetsmith
is item 9 bent Question is item 6 missing
Post #723383 14th Aug 2018 9:43am
Caterham
had this albeit on the pumpa set up which isn't adjustable.
although convinced it was fouling it wasn't until 3 of us were checking it and deciding what to do to resolve it we realised it wasn't actually fouling the bolt head at all.
I took the clip off and found a spring that fitted on the clip which held it up (not that it was needed Very Happy ), I believe it was a brake pad spring.
In my case if was a case of loosening the whole linkage assembly from the gearbox, moving it slightly and re-tightening it in a slightly different position.......and then all good Thumbs Up
good luck.
Post #723384 14th Aug 2018 9:53am
excossack
9 is not bent and 6 is present and correct. Maybe worth replacing. 1999 Defender TD5 110
Regards
John M0VAZ
Post #723386 14th Aug 2018 10:08am
excossack
good luck.
I think removing the clips and looking the U shape link will be the next move.
another tweaking session needed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #723387 14th Aug 2018 10:09am
dorsetsmith
ok
maybe the link has been fitted the wrong way around
Post #723389 14th Aug 2018 10:15am
Yet another area of the Puma engine installation where no expense was spared spent!
Post #723409 14th Aug 2018 12:10pm
excossack
dorsetsmith wrote:
ok
Cheers, I will take a look. Are those two small holes for R clips/split pins? 1999 Defender TD5 110
Regards
John M0VAZ
Post #723411 14th Aug 2018 12:13pm
dorsetsmith
Split Pin 1.5mm x 12mm Long
PS103121L
or FTC3674
Post #723414 14th Aug 2018 12:45pm
excossack
Interesting, as my link does not use R clips it has like flat clips that appears to be pressed onto the link. Like a circlip but square. 1999 Defender TD5 110
Regards
John M0VAZ
Post #723418 14th Aug 2018 1:25pm
