![]() | Home > Td5 > Adjusting difflock lever |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
or remove the small u bent connecting rod and fit a washer so the tail doesnt hit the bolt head? Cheers
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
I did think of that as well, but wasn't sure how the clip came off? 1999 Defender TD5 110
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Lift the curved up edge and slide the locking clip off.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Cheers all. I have adjusted the rod circle (12) but its the bottom circled bit that is catching on the bolt on the transfer case
![]() Regards John M0VAZ Econet Station 48 no clock |
![]() Click image to enlarge is item 9 bent ![]() |
had this albeit on the pumpa set up which isn't adjustable.
although convinced it was fouling it wasn't until 3 of us were checking it and deciding what to do to resolve it we realised it wasn't actually fouling the bolt head at all. I took the clip off and found a spring that fitted on the clip which held it up (not that it was needed ![]() In my case if was a case of loosening the whole linkage assembly from the gearbox, moving it slightly and re-tightening it in a slightly different position.......and then all good ![]() good luck. |
9 is not bent and 6 is present and correct. Maybe worth replacing. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I think removing the clips and looking the U shape link will be the next move. another tweaking session needed. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
ok
maybe the link has been fitted the wrong way around ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Yet another area of the Puma engine installation where no expense was spared spent!
Cheers, I will take a look. Are those two small holes for R clips/split pins? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Split Pin 1.5mm x 12mm Long
PS103121L or FTC3674 |
Interesting, as my link does not use R clips it has like flat clips that appears to be pressed onto the link. Like a circlip but square. 1999 Defender TD5 110
