Home > Puma (Tdci) > Back up alarm sounder
Page 2 of 3 <123>
Alexke wrote:
if my puma“s alarm goes off when disconnecting the battery : am I safe then?
thx
In that case you have a BBS and are safer than those without. Ths single biggest vulnerability of the Defender is the ease with which the non-BBS alarm can be disabled; it is (I understand) significantly harder to circumvent the BBS-fitted system silently. Your vehcile is by no means impregnable, but it is more likely that villains will opt for easier pickings.
Post #51162 5th Jan 2011 3:52pm
Alexke
Belgium
if they want it... they will always get it... Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #51274 6th Jan 2011 12:15am
noworries4x4
After my recent Bonnet loss at a Birmingham hotel, i have now fitted LED indicator bulbs and reduced the fuses in the indicator systems down to 5amp and the alarm fuses up to 20amp.
I have also fitted back up earth link from the battery to the chassis and + back up from the battery to the fuse box to stop battery cables being cut under the car.
Also fitted anti smash film to front windows why do we have to go to these lengths why cant Land Rover sort as standard ????
Any way back at the same hotel tonight dont think i am going to get much sleep If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #52274 10th Jan 2011 10:11pm
mse
Instead of the harness or aswell as?
You could have encased it
Im not sure why the fuses
Why not just fit a lock to the bonnet!! Mike
Post #52277 10th Jan 2011 10:23pm
NoDo$h
Anyone found if the backup is plug and play?
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #52501 12th Jan 2011 1:11am
PAULUS
England 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Can someone PM me details please
Post #68619 25th Apr 2011 10:16pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Me too, tried mine, disconnect battery and all is quiet! Guns and Landrovers .... anything else is irrelevant.
Post #68621 25th Apr 2011 10:30pm
mse
DId you let it charge first Question Thumbs Up
I cant remember the alarm ecu settings, i remember changing the sound the alarm makes, but not if i enabled BBS Mike
Post #68645 26th Apr 2011 9:29am
The definitive answer to the question about whether or not the BBUS is plug and play can now be revealed.
The wiring to support the BBUS is not fitted in its entirety, so you will need both the BBUS and one section of harness. This harness plugs into the main bulkhead harness (which does include the necessary wiring) and replaces the equivalent harness already on the vehicle. (An alternative would be to add the additional wires into the existing harness, but it doesn't look as though it is possible to obtain the necessary connector components either for the BBUS end or the bulkhead end).
The new harness supports both the BBUS and the non-battery-backed alarm sounders and it is possible to leave the existing one in place (the alarm will then sound both horns and both sounders).
Apart from the harness and adding the sounder, no other changes are needed.
Total cost on genuine parts is c. £170.
I do not intend to be more specific about the harness on a public forum, since, although most owners will know where the alarm system components are fitted I don't think it is sensible to advertise it.
Post #72227 23rd May 2011 9:33am
ickle
Thank you Blackwolf, this explains why after removing the headlight, and fishing around for an hour like a idiot, I couldn't fing the multiplug! Rolling Eyes
Post #72331 23rd May 2011 9:01pm
mse
Quick tip...remove the wing eye - its faster! although i probably shouldnt say that
Mine must have been a fluke Mike
Post #72394 23rd May 2011 11:00pm
mattlab
England 2009 Defender 110 Puma 2.4 USW Galway Green
if possible could someone pm me the details on this please, thanks. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #76307 16th Jun 2011 8:12pm
Barry
Is this the Factory fit option , think it was around £100 ish ?
The one they found for me had this fitted but I was told it was incase I needed to fit a winch Rolling with laughter 2011 Defender XS 110 Station Wagon - Rejected
2008 Discovery 3 XS Auto (Gone)
1997 Discovery ES Auto 300TDI (Traded in on a flat bed)
Post #76310 16th Jun 2011 8:23pm
LR90XS2011
please can someone PM me I live in birmingham and had someone follow me for 10 miles the other day and even followed me when I realised and doubled back, always look whose following me before I go home, used to doing this a I used to ride off road bikes and the garage was allways getting attacked and have had several stolen DEFENDER 90 TDCI XS,
Post #76352 17th Jun 2011 6:10am
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Do we have part numbers yet? D300 HSE 110
Post #76370 17th Jun 2011 10:09am
Page 2 of 3 <123>
