![]() | Home > Puma (Tdci) > Back up alarm sounder |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
if they want it... they will always get it... Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
After my recent Bonnet loss at a Birmingham hotel, i have now fitted LED indicator bulbs and reduced the fuses in the indicator systems down to 5amp and the alarm fuses up to 20amp.
I have also fitted back up earth link from the battery to the chassis and + back up from the battery to the fuse box to stop battery cables being cut under the car. Also fitted anti smash film to front windows why do we have to go to these lengths why cant Land Rover sort as standard ???? Any way back at the same hotel tonight dont think i am going to get much sleep If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Instead of the harness or aswell as? You could have encased it Im not sure why the fuses Why not just fit a lock to the bonnet!! Mike |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Anyone found if the backup is plug and play?
![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
PAULUS Member Since: 25 Apr 2011 Location: WORCESTERSHIRE Posts: 12 ![]() ![]() ![]() |
Can someone PM me details please
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Me too, tried mine, disconnect battery and all is quiet! Guns and Landrovers .... anything else is irrelevant. |
DId you let it charge first
![]() ![]() I cant remember the alarm ecu settings, i remember changing the sound the alarm makes, but not if i enabled BBS Mike |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17856 ![]() ![]() ![]() |
The definitive answer to the question about whether or not the BBUS is plug and play can now be revealed.
The wiring to support the BBUS is not fitted in its entirety, so you will need both the BBUS and one section of harness. This harness plugs into the main bulkhead harness (which does include the necessary wiring) and replaces the equivalent harness already on the vehicle. (An alternative would be to add the additional wires into the existing harness, but it doesn't look as though it is possible to obtain the necessary connector components either for the BBUS end or the bulkhead end). The new harness supports both the BBUS and the non-battery-backed alarm sounders and it is possible to leave the existing one in place (the alarm will then sound both horns and both sounders). Apart from the harness and adding the sounder, no other changes are needed. Total cost on genuine parts is c. �170. I do not intend to be more specific about the harness on a public forum, since, although most owners will know where the alarm system components are fitted I don't think it is sensible to advertise it. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Thank you Blackwolf, this explains why after removing the headlight, and fishing around for an hour like a idiot, I couldn't fing the multiplug!
Quick tip...remove the wing eye - its faster! although i probably shouldnt say that
Mine must have been a fluke Mike |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 ![]() ![]() ![]() |
if possible could someone pm me the details on this please, thanks. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Barry Member Since: 26 Apr 2011 Location: North East Posts: 137 ![]() ![]() |
Is this the Factory fit option , think it was around �100 ish ?
The one they found for me had this fitted but I was told it was incase I needed to fit a winch ![]() 2008 Discovery 3 XS Auto (Gone) 1997 Discovery ES Auto 300TDI (Traded in on a flat bed) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
please can someone PM me I live in birmingham and had someone follow me for 10 miles the other day and even followed me when I realised and doubled back, always look whose following me before I go home, used to doing this a I used to ride off road bikes and the garage was allways getting attacked and have had several stolen DEFENDER 90 TDCI XS,
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Do we have part numbers yet? D300 HSE 110
