Home > Maintenance & Modifications > Backlash sorted
Page 2 of 2 <12
Grenadier
shropshiredefender wrote:
The chap who looks after my Land Rover has 2 110s with Salisbury diffs. He welded the half shafts on both of his several years ago, the one pictured is used for heavy off roading and towing, the other is his daily driver.
That 'real' DCPU has made an appearance again. I'm not going to forgive or forget what you said Big Cry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #722830 11th Aug 2018 12:08pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Rolling with laughter Rolling with laughter Rolling with laughter
Post #722924 11th Aug 2018 8:31pm
shropshiredefender
Grenadier wrote:
What warning signs should we (who've yet to join the backlash club) be looking for? Sounds, feelings, visual? Thumbs Up
There can be a transmission "clunk" as the clutch engages and the splines on the half shaft rotate slightly in the drive flange. If you remove the rubber cap you can see if there is grease lubricating the half shaft, mechanics who know Defenders will grease at every service thus prolonging their life.
Welding the shaft to the flange creates a one piece half shaft eliminating another transmission wear point.
Post #722930 11th Aug 2018 8:51pm
Cupboard
Mine has recently developed a lovely clunk from the back.
If I try and drive with the handbrake on it doesn't clunk, but if I let the handbrake off and stand on the normal brakes it clunks horribly, once every time you take up drive after changing from reverse to forwards and back. It's almost like someone's strapped a cow bell underneath.
Post #722958 11th Aug 2018 10:32pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Fitting the single piece rear drive shafts to my 110 made a huge difference to backlash and how it drives.
Post #722971 12th Aug 2018 8:07am
shropshiredefender
Quick update
After 1k miles of motorway, B road and unpaved road driving the Defender feels tighter and smoother.
I've never driven a Land Rover (owned 2xSeries, RRC, 110 300tdi) with virtually no backlash before. even this 2011 110USW that had 40k on the clock when I bought it, and it's a revelation!
At very low speed on unpaved roads in the Dales it was more comfortable and generally easier to control through technical sections.
On the motorway it seemed more planted and smoother.
Post #724588 21st Aug 2018 3:32pm
Another culprit of backlash is a faulty clutch switch.
I meant to mention this before but it certainly does make driving though gear changes not nice at all and does induce a backlash where if driven properly is not needed and is a nicer drive without.
You can safely bridge the clutch switch on the 2.4. un-tested on the 2.2 so cannot comment.
It is supposed to be there to reduce shock loading on the driveline, but in my option causing the backlash and delay during gear changing it will cause more wear than any shock loading would induce whilst driven properly.
Bridging it also retains all anti stall features but in low range has the benefit of reducing the antistall rev threshold down to RPM you would expect in 1st high range without the higher increased revs which is pretty annoying in low range.
Much like a rev hange in low range 1st, removed with the bridges clutch switch.
Plug and play if you use the correct socket. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #725113 23rd Aug 2018 9:25pm
Page 2 of 2 <12
