![]() | Home > Technical > 2.2 TDCI 130 cutting boost |
I'm sure that I've read on here that this is a consequence of high coolant temperatures and the ECU cutting boost in self preservation. I vaguely remember talk of fitting a different thermostat to relieve the problem but you'd have to do a bit of searching to find the details. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 8th Aug 2018 11:51am. Edited 1 time in total |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Puma overheting or "ECU�s prevent mode for not overheat
That's the title of a post from South America which describes your problem. I remember similar from Australia but can't find them at the moment. http://www.defender2.net/forum/topic16002....e+overheat (That's another techy thing learned ![]() The ECU cuts power if the Cylinder Head Temperature Sensor goes out of range. The temperature gauge can read "normal" when this happens and no faults are recorded. I had the same symptoms when the radiator had a small leak. Be lucky ![]() |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3496 ![]() ![]() ![]() |
Thanks all. Will check coolant again but was fine this morning. Got it to Gib at least
![]() 1995 110 300TDI 1995 90 300TDI |
2600miles in and she hasn’t lost a drop of coolant. We are in Zagora and Morocco is proving to be every bit the adventure we hoped it would be.
More info to follow 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Update to this, lost no coolant over 5000miles. Never saw the issue in Morocco at 60mph max and no 70mph big 6th gear pulls. Once temps below 37/38 the issue has not manifested itself again over the next 2500 miles. I conclude it’s a limit by the ECU for high cylinder head/ EGT temps. Mine does have the bigger intercooler fitted. 1951 80" S1 2.0
