![]() | Home > Puma (Tdci) > Theft/Immobiliser alarm movement detecter disable for pets |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
lock it with key
| johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006
If only I could......at some point before I acquired the vehicle, the ignition was replaces, I only have keys that fit the ignition...... 2008 TDCi 2.4 XS CSW
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
Unplug the wire from the internal sensor if you can't lock with the key.
Some people say that simply putting some insulating tape over the sensor itself works, but I haven't tried this. |
Is there just the one sensor?
JD 2008 TDCi 2.4 XS CSW |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yes, just one sensor. It's held in place with a spring clip and so just pulls out of its' mounting point. Darren
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543
The advantage of taping over the sensor as opposed to using the key to lock the vehicle is that you still retain perimeter protection on the bonnet and doors. Defender 90XS SW
| Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230
Thanks everyone, I'll tape over them I think
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
On most cars if you have central locking, then locking with the key still arms the alarm without arming the volumetric sensor. However I don't thing this is the case with the Defender. |
If you're going via the Tunnel there's no real need to lock the car, its not as anyone can escape. |
Its the Normandie Express from Portsmouth
| JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142
Where are the sensors....?
when sitting in the drivers seat its above your right shoulder.
| All times are GMT |
