Home > Puma (Tdci) > Theft/Immobiliser alarm movement detecter disable for pets
johnnyd
Hi All
I am taking the dog over to France on a speedy crossing so need to be able to lock the car with the dog in it, what/how can I do to disable the movement detectors inside to achieve this, and how many are there?
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #720986 2nd Aug 2018 11:18am
dorsetsmith
lock it with key
Post #720989 2nd Aug 2018 11:25am
johnnyd
If only I could......at some point before I acquired the vehicle, the ignition was replaces, I only have keys that fit the ignition...... 2008 TDCi 2.4 XS CSW
Post #720990 2nd Aug 2018 11:29am
Unplug the wire from the internal sensor if you can't lock with the key.
Some people say that simply putting some insulating tape over the sensor itself works, but I haven't tried this.
Post #720991 2nd Aug 2018 11:33am
dorsetsmith
^^^^^ Thumbs Up
Post #720994 2nd Aug 2018 11:35am
johnnyd
Is there just the one sensor?
Post #720997 2nd Aug 2018 11:40am
Yes, just one sensor. It's held in place with a spring clip and so just pulls out of its' mounting point. Darren
Post #721006 2nd Aug 2018 12:41pm
discomog
The advantage of taping over the sensor as opposed to using the key to lock the vehicle is that you still retain perimeter protection on the bonnet and doors. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #721009 2nd Aug 2018 12:52pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Post #721036 2nd Aug 2018 1:49pm
johnnyd
Thanks everyone, I'll tape over them I think
Post #721044 2nd Aug 2018 2:08pm
zsd-puma
dorsetsmith wrote:
lock it with key
On most cars if you have central locking, then locking with the key still arms the alarm without arming the volumetric sensor. However I don't thing this is the case with the Defender.
Post #721060 2nd Aug 2018 3:16pm
zsd-puma
Re: Theft/Immobiliser alarm movement detecter disable for pe
johnnyd wrote:
Hi All
Thanks
JD
If you're going via the Tunnel there's no real need to lock the car, its not as anyone can escape.
Post #721061 2nd Aug 2018 3:18pm
johnnyd
Its the Normandie Express from Portsmouth Smile
Post #721384 4th Aug 2018 10:59am
JellyBean
Where are the sensors....?
Post #721512 5th Aug 2018 7:12am
zsd-puma
when sitting in the drivers seat its above your right shoulder.
Post #721533 5th Aug 2018 11:12am
