![]() | Home > Maintenance & Modifications > Recall Number: P022 Park Brake Oil Contamination |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Looking at the amount of oil that has leaked out overnight I think I will be pushing for a new transfer box. It also looks like the seal on the rear diff may also be leaking, no problems before the recall, but I can't confirm that due to the amount of oil that has sprayed everywhere.
I will let you know how I get on. Bob |
Quick update.
Told not to drive vehicle until LR Assist have had a look. Dealer is concerned that the transfer box may seize. Assist coming at 6am Bob |
Vehicle at dealers now, driven in after LR assist checked transfer box oil level and deemed OK to drive - have the written evidence for later use if needed !
New transfer box seal replaced as part of the recall was faulty and failed after 20 miles. Seal being replaced, transfer box has been checked and is ok. Somehow the rear diff seal was damaged whilst doing the recall, new seal arrives Wednesday. Bob |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
christ bob, this isn't good. your dealer seems to be totally incompetent.
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
How the hell did they manage to knacker the diff seal? Makes you wonder if the first transfer box seal was faulty or they made a cods ear of it. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I think the latter ! All I know is that they did take the rear prop off, new bolts front and rear, probably used a club hammer to put it back on and destroyed both the seals. BigMike They appear to be now. They used to be exceptional but the standards have slipped recently - I did see them advertise for mechanics a short while ago so my guess is all the best ones have moved on. The dealer principal knows that I don't call LR customer service, I go directly to the executive office, so I am sure it will be OK when it comes out - famous last words ! Bob |
All fixed
The new seal fitted to the transfer box under the recall was faulty and they have no idea why the diff seal started to leak as well. Guess they would never own up to a bodged job so we will never know the truth. Bob |
| bearman Member Since: 13 Jul 2010 Location: East London Posts: 5
| ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153
i've phoned LR and cancelled my appointment, too scared they break something - my brake seems quite fine, i'll take my chances without the recall work... www.ralton.co.za
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
mine went in yesterday.
new seal, re-fitted brake shoes. i also asked them to check on a conk when changing gear. diagnosed as loose bolts/nuts on the brake drum. clonk now gone and the drive is smooth again. so far no signs of an oil leak - i will keep checking, my drive was/is clean of drips so it should be easy to check if it starts leaking |
| adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204
I logged into Topix and says my car has this announcement... Does this work get carried out free of charge even if outside of warranty? P022 - PARK BRAKE OIL CONTAMINATION |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
i hope so as mine still needs doing
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 238
I have noticed this problem. Is it only repaired in the guaranty periode or also when the car is out of waranty?
Cheers Q. |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
In my case (Chile) I received an email from the dealer long after the warranty period. Puma 110" SW
