![]() | Home > My Defender > here she is |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049 ![]() ![]() |
Good luck for Monday
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Cheers fella , she’s been dropped off , it’s worse than going to the dentist I believe
taken from dvla website , light and seal are now major defects , blimey
Date tested 30 July 2018 Fail Mileage 135,903 miles MOT test number 7011 3589 3001 Test location View test location Repair immediately (major defects): Nearside Front Position lamp not working (4.2.1 (a)) Drag link end ball joint dust cover insecure so that it no longer prevents the ingress of dirt (2.1.3 (g) (ii)) Monitor and repair if necessary (advisories): Drag link end ball joint has slight play (2.1.3 (b) (i)) |
She’s home , next up , new drag link and series windscreen/ flat roof
The boss says I gotta leave it in one piece for a little while , so sept 9th is next pit day , so that’s it for now , catch ya all soon
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
This as always is a welcome change to the mint ground up rebuilds which I love ,to know you are going to throw this in the mud makes it all the more special .Here's my TDi 200 a few years ago.
^^^ nice pic legin
![]() Great she passed the mot razz with not much needed to be done ![]() Happy holiday till the 9th sep ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Thanks lads , it’s here to be used
And we off , screen out , screen frame in , need to drill the bottom of the frame to locate it onto the defender bulkhead pins , then i’ll Work out where to cut the roof to drop down on to the flat series screen , but before all that , the bulkhead has a hole in it , now there’s a surprise
![]() ![]() Click image to enlarge |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Have you tried to source a series pick up roof? That would fit more easily with the windscreen. Trying to reprofile and keep waterproof the defender roof will be quite a task. 1995 Defender 110 CSW
1971 SIIA Lightweight |
3 hours of work done , drilled the frame to drop it onto the pins , and then go round n round n round making all the gaps look half good , need to make some plates to hold the bottom of the screen , then it’s shut the doors n fold the roof , my daughter says leave the roof and go rag top , so might even go that route , in the mean time , i’ll keep plodding along , if a series roof appears , I may grab it . As you can tell , it did look smart with the roof off . Anyways don’t look much different , but lots done
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Certainly different
![]() Looking forward to the finished look ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
cheers fella , its a new day and i realise i need the hardtop series roof , as its flat as i want , and not the rounded pick up version , yep i`ll have to cut it to suit the rear bulkhead glass bit , and on the way to work , i pass a ragtop version , hmmmmmm they do look good . thats the trouble with these , you can have so many versions , i did spot on the searching web , a series with a ply roof , now that would be easier , make a metal frame to hold the thing square , tiled , or thatched roof at that , yee harr
