familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Yes you can. Very tight but have seen them on a few websites. http://www.explorecampers.com/my-defender/ 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 607 ![]() ![]() |
734 miles and a ferry crossing. All at 70-75 mph. Two tanks used. Not too bad considering the load.
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
Defender missing from photo but went and collected this.
Project?
Not sure yet, chap I shoot with rang me and offered it me so I said yes, he says it has an intermittent fault where it stutters as if its running out of fuel, I did 5 mile in it last night after picking it up and was fine to me.
Think it may of been on air originally and some one has fitted HD springs to it and its too harsh of a ride for my liking |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
Ashcroft Defender transfer case in the post to replace the 1.2 ratio Disco one. 1999 Defender TD5 110
Can't beat Ashcroft
![]() Andy, is it a td5? |
Hope not Greeni. See you at next LR event @ Babell 1999 Defender TD5 110
Hope the weather holds out still
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Water everywhere comin frm the radiator cold level tank and a hot smell...
Temp gauge wus fine and didnt over heat! Any ideas Its prob put a stop to salisbury plain this friday ![]() |
Indeed it is, TD5 Manual with 83k, it drives fine, only reason I picked it up on the trailer was because it's easier than getting a lift for it ![]() Did show a fault on the MAF so I cleared that and fitted a spare one, no fault come back up so all seems good. Non sunroof with AC too |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
Soo last week whilst running breather lines I found an oil leak coming out of the adaptor shaft housing drain hole.
Soo yesterday the Tbox came off to have a look and yes the rear gearbox oil seal was leaking with a small telltale weaping coming down from it. £25 for a seal later ![]() and a few hours work to refit and reassemble and fingers crossed no more leaks. ![]() Whilst I was in there I had a look at the adaptor shaft and re-greased it ![]() ![]() Click image to enlarge ![]() Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
I’d try a new cap first, it’s cheap and they sometimes fail. Only buy genuine or oem. Ray My build thread http://www.defender2.net/forum/topic17615.html |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Not today, a little while ago, dragged the Rapier trailer out and went to get some logs. 100 euro for this load
![]() Click image to enlarge Which, when unloaded and stacked looks like this (the pile across the back of the store) ![]() Click image to enlarge |
