![]() | Home > Puma (Tdci) > FORScan OBDII scanner works on PUMA 2.4 TDCI |
4wd-junky Member Since: 31 Aug 2014 Location: UK Posts: 89 ![]() ![]() |
Following another members post about FORScan, I too have just successfully connected FORScan to my PUMA using a cheap usb adapter (ebay eBay Item No. 153070327324), Windows 10 laptop and FORSCan 2.3.16 BETA https://forscan.org/download.html
Screen shots attached. (I have deleted my VIN number from these) Please note, so far I have only viewed settings and faults. I have not performed any resetting or learning functions, although the other member has confirmed that pump and pilot learning functions work. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Last edited by 4wd-junky on 19th Apr 2019 9:08pm. Edited 1 time in total |
Yes, it's a cheap solution that should help DIY Defender owners keep their 'transit' engines running
ampstp Member Since: 04 Jul 2018 Location: kington Posts: 9 ![]() ![]() ![]() |
Apart from being able to execute the service routines that are now assessable, one clear benefit of the forscan is being able to graph fuel pressure (desired) against fuel pressure (actual) thus checking the health of the entire low and high pressure system including rail sensor and VCV in my case over a 15 minute drive at various speeds and loads. Great free software! Obviously you can add many sensors to the graph CHT, fuel temperature e tc e tc to help with fault finding. My vehicle was simply overdue for a VIV clean and pump re-learn.
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Another vote from me for ForScan.
Used it to do Pump Learn and Pilot Correction - talked me through the whole process giving me all the requirements to allow it to complete such as fuel temp and coolant temp. Drives like a different vehicle ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Another + for Forscan. I could test and remove (so far) some stouborn DTCs. Pump and injector calibrations done. I could not do it neither with SDD nor Nanocom.
It also reads all injectors 16 digit codes which is nearly impossible unless you use a 10-20x handlens. Puma 110" SW ............................................................. Earth first. Other planets later |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
My ebay speshal arrived this morning, will have a look over the weekend with FORScan
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
FORScan.....
sorry, sounds too much like ForeSkin ![]() ![]() ![]() |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Mine has only the ECU and the 10AS. No ABS, ETC or anything else. I'd like to try the FORscan in addition to the Nanocom. |
The whole thing is to get a obd2 plug that works. I reckon it needs to be Elm327 with HS capability. A generic elm327 wont work. Puma 110" SW
this one works
https://www.ebay.co.uk/itm/Modified-ELM327...2749.l2649 |
It does.
Now I would like to know if anyone got a bluetooth unit that in fact works. Puma 110" SW ............................................................. Earth first. Other planets later |
Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71 ![]() ![]() |
I read this thread and bought a lead from the link. It arrived today and I can confirm it works fine.
I have a question to the people that are more familiar with forscan. Is there a way of checking if the injectors have been Set up correctly or do you have to do the re learn ? Cheers Tom |
Same for my car..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
