Home > Technical > question re: upgraded Ashcroft HD halfshafts
Page 2 of 5 <12345>
^^^^ I did notice this one, probably go with that. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #718404 18th Jul 2018 6:24pm
I have gone for the Kay's fasteners option that meets DIN912 which is the same as the specs on Allfix's site for the same bolts.
These are 12.9 as 10.9 aren't readily available unless in large quantities.
They aren't tightened to a very high torque as the torque specs in the WSM state and I've gone with A4 SS washers.
They should be okay by going with black bolts which aren't zinc / electro plated and the SS washers also.
So should keep and Hydrogen issues away and also not corrode too fast. (Hardly at all.)
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #718429 18th Jul 2018 8:11pm
For not a lot more, you can have a zinc plated version:
https://www.ebay.co.uk/itm/M10-10mm-CAP-HE...Z9y_n_09GA Darren
Post #718454 18th Jul 2018 9:11pm
jst
M10 x 1.25 or others? i see M10 (10mm dia) surely they are both 10mm dia Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718457 18th Jul 2018 9:24pm
jst
i have used screw caps on all my previous vehicles, i torque as specified to 65, i also use RTV and Nord Locs with 12.9 screw caps, just cant recall the thread size currently! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718458 18th Jul 2018 9:25pm
Are you talking about whether they are M10 x 1.5 pitch or M10 x 1.25 fine pitch? Confused Darren
Post #718465 18th Jul 2018 9:48pm
Well I've just gone 1.5 pitch standard.
These:
https://www.ebay.co.uk/itm/M10-10mm-HIGH-T...2749.l2649
I cannot imagine them being fine pitch to be honest. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #718481 19th Jul 2018 12:01am
jst
I don't recall them being fine pitch, just interesting they state m10(10mm) or m10 1.25 as the way to differentiate it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718488 19th Jul 2018 6:28am
Ah, ok. I think that's just down to the vagaries of eBay advert descriptions. M10 is 10mm regardless of the thread pitch. Darren
Post #718503 19th Jul 2018 8:15am
The drive flange bolts are M10 ISO Metric Coarse Series, i.e., 1.5mm pitch.
Post #718512 19th Jul 2018 8:43am
That’s a relief.
So that’s the bolt type, size, length and pitch conundrum over. 👍🏻
I’m guessing that no thread locker is best as mentioned and the spring washer is fine for those purposes.
I’m assumeing that a little copper grease should not be used either.
I bit the bullet earlier and bought two pairs of HD flanges and the flange nut tool. Luckily I have plenty of grease that’s fresh. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #718570 19th Jul 2018 3:11pm
jst
i loctite all mine in. I also use Nord locs on LHS side of any vehicle running 33" or larger Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718606 19th Jul 2018 6:35pm
Bolts arrived today, waiting on the flanges that should be also.
I will also need an 8mm male hex drive bit to suit as well. Best to go 8mm to 3/8” or 1/2” female to suit torque wrench?
My 3/8” goes up to 65nm if I recall correctly which should be fine.
I looked at the WSM today, and I couldn’t seem to come across the right sections I was hoping to.
The only useful info I found was axle oil capacity on a 90 is 1.7L.
I’m considering changing it on the front as the back was done last week.
I couldn’t seem to find axle oil drain plug torque figures or info on the halfshafts / drive flanges and torque.
I know it’s mentioned on this thread but it would be useful to see the relevant info unless I’m looking in the wrong sections! ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #718746 20th Jul 2018 2:33pm
I've never felt the need to use a torque wrench on axle fill and drain plugs. As long as you're not a gorilla, it's easy enough to tell when they're tight enough. Darren
Post #718754 20th Jul 2018 3:50pm
jst
i would use 1/2 8mm allen.
ordered bolts yesterday for mine and 4 sets of the HD DM, already have ashcroft shafts fitted.
65Nm is correct. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718757 20th Jul 2018 4:12pm
Page 2 of 5 <12345>
