![]() | Home > Technical > question re: upgraded Ashcroft HD halfshafts |
I have gone for the Kay's fasteners option that meets DIN912 which is the same as the specs on Allfix's site for the same bolts.
These are 12.9 as 10.9 aren't readily available unless in large quantities. They aren't tightened to a very high torque as the torque specs in the WSM state and I've gone with A4 SS washers. They should be okay by going with black bolts which aren't zinc / electro plated and the SS washers also. So should keep and Hydrogen issues away and also not corrode too fast. (Hardly at all.) ![]() Click image to enlarge _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
For not a lot more, you can have a zinc plated version:
https://www.ebay.co.uk/itm/M10-10mm-CAP-HE...Z9y_n_09GA Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8318 ![]() ![]() ![]() |
M10 x 1.25 or others? i see M10 (10mm dia) surely they are both 10mm dia Cheers
i have used screw caps on all my previous vehicles, i torque as specified to 65, i also use RTV and Nord Locs with 12.9 screw caps, just cant recall the thread size currently! Cheers
Are you talking about whether they are M10 x 1.5 pitch or M10 x 1.25 fine pitch?
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Well I've just gone 1.5 pitch standard.
These: https://www.ebay.co.uk/itm/M10-10mm-HIGH-T...2749.l2649 I cannot imagine them being fine pitch to be honest. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I don't recall them being fine pitch, just interesting they state m10(10mm) or m10 1.25 as the way to differentiate it! Cheers
Ah, ok. I think that's just down to the vagaries of eBay advert descriptions. M10 is 10mm regardless of the thread pitch. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
The drive flange bolts are M10 ISO Metric Coarse Series, i.e., 1.5mm pitch.
That’s a relief.
So that’s the bolt type, size, length and pitch conundrum over. 👍🏻 I’m guessing that no thread locker is best as mentioned and the spring washer is fine for those purposes. I’m assumeing that a little copper grease should not be used either. I bit the bullet earlier and bought two pairs of HD flanges and the flange nut tool. Luckily I have plenty of grease that’s fresh. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
i loctite all mine in. I also use Nord locs on LHS side of any vehicle running 33" or larger Cheers
Bolts arrived today, waiting on the flanges that should be also.
I will also need an 8mm male hex drive bit to suit as well. Best to go 8mm to 3/8” or 1/2” female to suit torque wrench? My 3/8” goes up to 65nm if I recall correctly which should be fine. I looked at the WSM today, and I couldn’t seem to come across the right sections I was hoping to. The only useful info I found was axle oil capacity on a 90 is 1.7L. I’m considering changing it on the front as the back was done last week. I couldn’t seem to find axle oil drain plug torque figures or info on the halfshafts / drive flanges and torque. I know it’s mentioned on this thread but it would be useful to see the relevant info unless I’m looking in the wrong sections! _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I've never felt the need to use a torque wrench on axle fill and drain plugs. As long as you're not a gorilla, it's easy enough to tell when they're tight enough. Darren
i would use 1/2 8mm allen.
ordered bolts yesterday for mine and 4 sets of the HD DM, already have ashcroft shafts fitted. 65Nm is correct. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
