Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
double post 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Ghound Member Since: 03 Jul 2018 Location: northern ireland Posts: 45 ![]() ![]() ![]() |
I fitted a Mudstuff rear card to the HD galved door on my 110TD5, a very nice item, gives it a factory look.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Just drove it, had to go an get some hay bales in the trailer. Not usually at this time of year.
![]() Liking the new wax I've used on my 90, to the eye it appears a darker shade than the #26 Yellow I have been using for a while. Been thinking about getting parts Galvanized, but more a winter thing as too busy. What do most of you expect to pay for blasting and Galvanizing? Obviously depends on how many parts but any guides? _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1872 ![]() ![]() ![]() |
Put the Mantec roof bars back on ready for transporting the missus to vend at a yarn show.
Considering they are under 12 months old and spend nearly all the time in the shed the finish is starting to look flakey in places. ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
You put your wife on the roof bars to transport her? 😂😂👍🏻 _\Hennessey|Venom| F5/___
Some days it would be preferable, but her flailing in protest would cause too much damage to the roof
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Blasting is cheap, I’ve just had an 80” bulkhead and a few other small parts done for £50, Galvanising will be expensive if you have only a small quantity of parts, and some places won’t do one off/small items. Our local (Wessex galvanisers) were good, £130 for a Series chassis, and £120 for all the cappings, screen frame etc, Now they charge £10 per item on small parts, as they got fed up with people wanting an absolutely flawless Finnish, If you can? Your best bet is to find someone who also needs some done, and double up on the quantity. ![]() Wanted, Forward Control Anything considered. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
Took the scenic route home...
![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
I made up a window vent, it was a rush job as i need it for tomorrow. It slips into the window channel, then the window slides into one end of the vent and the window catch keeps it closed.
It's a bit bigger than i need, so I'll knock up a nicer set for the 110 next week. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
Very nice job Ghound !
I like your window vents ! ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
For my Defender, I posted off a transfer case and centre ATB to get made up into a complete TC to replace the Disco one in the 110 in preparation to return back to standard Defender TC 1999 Defender TD5 110
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
Good that your still lurking and hoping all will be ok for you ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Went to D44 for a Service, brake fluid change, replacement sump, transferbox mounts, rear diff pinion oil seal.
Ended up needing new front brake pads, I thought they were okay but were a bit low. Wish they would have told me before fitting though, cost that bit more than I planned for the brake pads. There was traces of water in the rear axle oil so got it sorted out just in time! Rear halfshafts and drive flanges are worn too. Costs are getting hard to justify! ![]() I can't understand why I get next to no issues with the front but often something with the rear driveline. Had the rear diff pinion oil seal replaced multiple times and the flange for Genuine as well, and after about 2 years it starts again. At least most things are sorted now though, just goes to show how you can't always tell issues with your own vehicle until experienced people know what to look for. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
pux146 Member Since: 30 Apr 2018 Location: Wiltshire Posts: 121 ![]() ![]() |
Added some Mantec roof bars. 2007 2.4 90 fettled & remapped.
