Home > Puma (Tdci) > Puma synchro gearbox alternative slick shift
Page 2 of 2 <12
diggers1981
2009 Defender 90 Puma 2.4 XS CSW Santorini Black
It is tilted backwards but you can also see in the video that the lever is tilted across as well, with this silver ball type lever it is obviously just a lot more prominent than the black version.
Post #716271 5th Jul 2018 3:38pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Thnx ben for the swift reply Thumbs Up
But.... we drive at the other side of the road this this would mean that the gearlever is further away? Am i correct? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #716272 5th Jul 2018 3:42pm
diggers1981
we have a customer in France that runs 3 defenders and he has the shift-r fitted to all 3 and he loves how it feels. The gearstick itself sits a bit further back and is angled slightly, but it does not sit anymore to one side.
Post #716273 5th Jul 2018 3:52pm
Tdi4
Thnx ben for the update Thumbs Up
I’ll keep an eye on your website. To see if you ever make one without the across angle. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #716278 5th Jul 2018 4:12pm
Beeder wrote:
Just a quick update, I fitted this slick shift over the weekend so I’d though I’d pass on my thoughts as it’s a £200 purchase
Really Easy to fit but a couple of things I’m not happy about - one I have a bearmachmgear stick with an aluminium knob which now won’t fit correctly - it won’t push all the way down so the locating slots clip into place and there isn’t enough plastic on them to make the slot larger so they do engage , so a £200 gearstick amd £200 slick shift that don’t fit together. The original gearstick is exactly the same.
That gearstick is not fitted correctly, and if the original once removed was the same it also wasn't fitted back correctly.
That foam that is present I agree with TMD isn't factory fit or at least isn't typical.
As it stands you gearstick(s) aren't located properly and are NOT secure.
I would not recommend you drive it like that.
Those two clips locate onto plastic lugs, which are white Nylon. There is bad should be no adjustment needed at all.
Looking at it and as Ben @ TMD said that foam is in the way, it must be partially removed to allow the tabs to locate.
The two tabs are each side and square on, so thinklooking forward towards the engine / vehicle each lug on the gearstick mech is to each side where the doors are and there are two.
And the clips on the gearstick are located over these, they simply clip over.
The foam should also in my opinion not interfere with and movement of the gearstick in any gear.
Remove some of the foam, locate the tabs to the lugs and it will sit square and be securely locked in place.
At face value, it looks to me like there is nothing wrong with the gearstick, it isn't fitted or located correctly. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #716282 5th Jul 2018 4:31pm
Page 2 of 2 <12
