Home > Puma (Tdci) > Battery Terminals
Battery Terminals
Hello folks,
Has anybody fitted better battery terminals? The existing ones on mine are impossible to tighten up properly. No matter how tight I do the nuts, it's still possible to move the terminals on their posts. Darren
Post #715320 30th Jun 2018 2:20pm
zsd-puma
I haven't on a Defender, but I have on other cars. The earth terminal is easily replaced, there are various crimp on, clamp on or even solder on terminals.
The Positive terminal is a little more difficult as it contains a massive fuse, so it becomes more complicated if you want to retain the fuse.
It helps if you loosen off the terminals, then tap the terminal down onto the post using a large socket and a small hammer, before tightening them back up. Putting water pump pliers or mole grips on the tail of the connector to stop it rotating as you tighten the nut also helps.
If your battery posts are a little out of spec (cheap batteries) of if they're worn from the terminals being moved about or not fitted correctly, you can cut out a piece of thin steel from a tin can and wrap around the post before putting the terminals back on.
Post #715322 30th Jun 2018 2:53pm
Thanks. There's nothing wrong with the battery posts. It's the original LR battery and it's in good condition. I quite like the idea of wrapping some thin steel around the posts to pad them out but I would be interested to hear if anybody has replaced them with something more conventional. Darren
Post #715339 30th Jun 2018 5:44pm
johnnyd
Re: Battery Terminals
LandRoverAnorak wrote:
Hello folks,
I had the same issue when replacing the battery recently! I found tapping the terminal bracket onto the lead terminal with a small hammer helped a lot, make sure you don’t clonk the terminal though as removing it might then be difficult......the terminal brackets did then tighten securely....... 2008 TDCi 2.4 XS CSW
Post #715342 30th Jun 2018 6:12pm
zsd-puma
That's why I suggested putting a socket over the terminal, get one just larger than the battery post and it drives the terminal not the post. Wink
Post #715351 30th Jun 2018 7:00pm
zsd-puma
I've fitted these to replace the pressed steel ones (which always distort) on other cars.
https://www.autosparks.co.uk/electrical-co...-0-30.html
They're easy enough to solder on, then you can put some heat shrink over the cable join to make it neat. But I'm still not sure what you'd do with the positive terminal.
Post #715352 30th Jun 2018 7:04pm
Solved the problem this morning. Made some shims, from copper rather than steel as it was easier to work with, and it's worked a treat. Thanks for the idea Thumbs Up
http://www.defender2.net/forum/post716692.html#716692
 Darren
Post #716693 8th Jul 2018 11:30am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I replaced my negative clamp with the type with a 10mm stud that accepts a 10mm cable lug crimped onto the negative cable to makes wiring accessories easier, such as my negative winch cable. I didn’t actually have a problem with lack of tightness on the battery post on the Puma but used the copper shim solution on my Son’s 300tdi to good effect. 2010 Defender 110 Station Wagon, Santorini Black.
Post #716695 8th Jul 2018 11:44am
zsd-puma
Actually I hadn't thought of cutting a bit off some copper pipe, better than steel.
Post #716700 8th Jul 2018 12:00pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I have replaced mine with this one (it is from Iveco Daily):
https://goo.gl/images/aXkgrM
The original one was too loose, not possible to tight anymore. Janusz
www.yahodeville.com
Post #716904 9th Jul 2018 5:47pm
