![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Thank you
![]() @harry, no worries I was just being lazy ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Busy yesterday with rear springs. With the defender loaded up to go on holiday last year the rear springs (2:5 inch lowered) felt a bit wallowly and looked very low with the weight so I decided to put some 1 inch lowered springs on for this year so should gain an inch and a half. I actually gained 2 and a half inches so I’m guessing the old ones had settled a lot and the new ones need to settle in a bit.
![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
Sorry but I’m missing summat, what’s the point of the provent?
To stop all the discarded oil from being thrown back through the engine. Ray
So are you going to have to keep an eye on the engine oil level? Plus dispose of the waste oil?
It’s only from the breather on top of the rocker cover so the oil level won’t go down any differently, but what used to be sent through the turbo and engine will now be filtered out to a pipe that has a tap on the end to be drained occasionally. Ray
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Loaded up for the brake overhaul tomorrow.
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
wheel bearings at same time?
Hadn’t planned on it but the garage will stick them on if it needs them
We now have the cruise switches in. Just a few wires to connect up to the ecu
![]() Click image to enlarge ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
It even lights up like the rest
![]() ![]() Click image to enlarge Shame the hazard switch doesn’t at the moment, might have to get a new one ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5369 ![]() ![]() |
the only thing you need is a rubber grommet for that hole, next to the stalks or another feature added
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
It will be getting a grommet in there when the job is fully done
