![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Got my mate who makes stickers to print me out a negative version of a cruise control sticker to put on the cruise on/off switch this week.
Stuck it on in place ![]() Click image to enlarge Scratch off the paint in the gaps ![]() Click image to enlarge And after removing the sticker I don’t think it looks too bad, not perfect but passable. ![]() Click image to enlarge Got to get it all wired now ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
That looks great👍 Which cruise control kit have you fitted? 2002 110 td5
I’ve just bought the two disco switches and I’m going to wire it up myself..............................hopefully
Understood...let us know how it works. Although I presume my 5th gear ratio would scupper it? 2002 110 td5
Forgot to say, I bought a speedo healer too as I’ve got the 1:22 ratio transfer box in, speedo healer should work with yours if your planning on fitting cruise. Ray
Hi Harry, I’m fitting the column switch just like yours, I’d seen your pics before so was going to copy
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
Looking forward to seeing the finished result! Being honest, I copied the idea from someone else on this forum
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Finally piped up the provent so we’ll see how much oil it chucks out now
![]() ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
Harry, how did mount the D2 switch ? I’ve trimmed my cowl ready to fit but I have no idea how I’m going to line it up and fit it first and the get the cowl on.
I was going to fit an L shape bracket to the bottom cowl and attach the switch to that then Slot the top cowl over the switch. Ray
My build thread http://www.defender2.net/forum/topic17615.html Last edited by mk1collector on 28th Jun 2018 11:24pm. Edited 1 time in total |
Just a quick question, on the disco 2 switch, of the three wires in was the black wire the live in? Ray My build thread http://www.defender2.net/forum/topic17615.html |
Hi AJC, there's a few photos I posted in this thread if that helps. I fitted it to the bottom section of the cowl only, it seems pretty sturdy when the cowl is all bolted back together but it took a while to get it flush hence the washers under the bracket http://www.defender2.net/forum/topic58769-15.html Mk1collector - Sorry but off the top of my head I can't remember which way around and I'm currently in the wrong continent to check the Defender. Do you have a multimeter that you can check with? [/quote] 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Thanks Harry, that's great. My job for tomorrow afternoon
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
Nice job on the cruise control Ray
