![]() | Home > My Defender > Proctas Defender 300TDI |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5355 ![]() ![]() |
well what ever it was seems to have stopped
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
Just get the tyres!!!.. Don't wait any longer otherwise something else will crop up and get in the way...
I am hoping to get them next month, or soon as the 306 is through the MOT. This has to go through one now, and it may have expired now
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11067 ![]() ![]() |
Good luck with the 306
You
![]() ![]() ![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge The Fuel Injector Spill Rail has decided to fail on the pump end, jugging nearly £20 quids worth of diesel!! It looks like its gone from the pump end not the injector side. Read a thread stating it could be just the washers failing. but its finding the part number for the banjo that goes into the pump. I can get the ones up for the injectors Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I think I have sorted out the problem, just got to wait for the replacement bolt and washer, Also eyeing a ICE install for this, A bit back in the day but that's how I role.
Good to hear you have got to the route of the problem
![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Yeah Mash something a little bit retro, weather it will work or not that's the thing.
![]() ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
You'll need a pretty big hole for one of those eight tracks
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Well that's procta's defender out of action until the parts arrive sadly.
![]() I managed to get hold of a pair of washers from the place that deals with Land Rovers. Fitted the washers and I still had the same trouble. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge turns out this area has a split ![]() ![]() ![]() Click image to enlarge you might not be able to make it out, but its right on the end where the banjo bolt goes through. So we are dead in the water sadly. But that didn't stop me getting on with other little things ![]() ![]() Click image to enlarge ![]() Click image to enlarge much better now! ![]() Click image to enlarge Also installed my tufflift today ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() I have a few things on order now, and i am going to bite the bullet and buy my tyres while its off the road. My exhaust has seen better days has it not!! front section is about on its last legs ( only fitted it last year) ![]() Click image to enlarge the centre section thing was new when i bought the car two years ago, thats blowing now at both ends one end is about to drop off tale end ![]() Click image to enlarge the rear pipes dead ![]() Click image to enlarge So i have just ordered off the three sections as a get me through the mot, so that i can push budget for tyres and the fuel system, and what ever else its going to need. Not sure where i will take it for the mot yet, as the place that did the peugeot 306, the mot tester is a bit of a joker, with the advisories he has gave the car ![]() I have a timing belt kit ordered off too, so thats going to go on. A long with a few other bits and pieces that i have. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
well I have had a bus load of parts delivered, mainly exhaust, got my replacement fuel return, but looks like I need a replacement olive, so that's been on order. Also My ICE came too, which I will show you at some point, I am thinking on buying a few 4 new speakers too, and a little two upgrades from mud. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Good to hear the problems been identified and a good pile of parts are on route
Well my New ICE is a CD Changer setup, I had the same setup that I installed in my 1st car which was worth more than the car at the time!
I am going to mount the CD changer under the middle seat with one of those storage inserts from YRM metals. Only way really I can mount it nicely plus its less trouble for wiring. ![]() Also I have ordered off some speakers too! Which those will be the easiest upgrade to install. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Isn’t a cd changer a little old tech now a days? When are the new wheels going on? Ray
