Home > Wheels & Tyres > Running a spare of a different size from the rest??
m3vert
Scotland 2011 Defender 110 2.5 TD PU Stornoway Grey
Ok I know my spare should ideally be the same size as the tyre it is replacing, however for some stupid reason my spare that I got from the garage I bought it from is totally different! Long story short I am stuck with it. I will replace it with the same in due course but for now, if I had to use the spare in an emergency is it likely to cause any issues to the drive train and or handling??
I am running 275 75 16 BF Goodrich and the spare is a crappy General Grabber 225 75 16. So an overall size difference of 37mm I think?
Anyone advise if it will be ok or should I go out and get the correct tyre ASAP??
Post #713172 19th Jun 2018 3:04pm
Martin
Site Admin
First off check both sizes as I don't think 275/75R16 is a common size, BFG or otherwise Smile
Plugging your sizes into the "comparison" tab here: https://tiresize.com/calculator/
Gives a circumference difference of 10%, which really is too much. I'd run it to get me off the hard shoulder but not for any considerable distance.
Check the size of the big tyre and do the calc Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #713175 19th Jun 2018 3:12pm
jst
sizes look a bit out on larger tyre. 285.75?
your 275.75R16 is 818.9mm (32.2")
high your 225.75R16 is 743.5mm high. (29.2") Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #713180 19th Jun 2018 3:30pm
m3vert
Cheers Martin, I am away from the car for another week or so, so cannot check. My Wife checked and assured me that was the size on though? I did think it was a bit much, we are doing a good few miles on an upcoming holiday and am thinking I should probably bite the bullet and get another steel the same as the existing wheels and a tyre the same Sad
My next issue is I don't know where the modular steels came from!! Are they all the same offset wise? Nah I doubt it Big Cry
Thanks for your help Thumbs Up
Post #713181 19th Jun 2018 3:33pm
Stiff1
Due to a recent puncture on the Zafira while in France, I realised the spare was a 16 while the ones on the car were all 17's. Did the job of getting me to a repair centre but was concerned.
I do remember a past post discussing this and the point that we all kept coming back to was that a lot of cars ship with a space saving spare which is of a smaller diameter and width and this seems fine all be it with the caveat of driving under 50ish and for a limited mileage.
Post #713252 19th Jun 2018 7:36pm
Martin
Site Admin
16/17 refer to the wheel size (diameter in inches) not the tyre. Chances are they are fitted with different profile (sidewalk height) tyres and so are overall the same diameter when shod with tyres.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #713253 19th Jun 2018 7:38pm
Stiff1
Could well be Martin, its back under the car and hopefully will stay there until I return home.
The point still remains, space savers are very different in all dimensions to the standard wheel.
The previous post came about when the OP had some expensive/ wide wheels and wanted to save a bit with a cheaper/ smaller on the back with a cover if I recall.
Post #713254 19th Jun 2018 7:43pm
A constant 4wd is very different to an ordinary car. The centre differential won't tolerate large discrepancies in wheel / tyre diameter . Darren
Post #713257 19th Jun 2018 7:56pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Regardless of the size written on the tyre and the numbers the online calculator give, they are only 'Design nominal' dimensions whereas the actual tyre is likely to be different.
Best best is to physically measure the unladen diameter of both to determine the real difference.
Ideally your aiming for a similar OD and in an emergency situation wheel offset or tyre tread width won't matter. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #713270 19th Jun 2018 8:29pm
m3vert
Thanks folks, appreciate all the feedback. My Wife has just sent me a photo of the tyre and she is clearly dsylexic! The ones on the motor are 285-75-16 indeed and not 275! So I guess this makes the issue even more of a problem.
Since i do not know what steel wheels are fitted (black modulars but no idea who makes them or style) I think I will stick with the steel wheel that I have as a spare, even though it will no doubt be slightly different offset and try and pick up another 285-75-16 before we set off on our holiday down south!
Post #713274 19th Jun 2018 8:41pm
Sorry to add to your woes but if your spare is a standard LR steel wheel then it won't be anywhere near wide enough for a 285 tyre. I'm not sure what might be a suitable diameter alternative, off hand. Darren
Post #713380 20th Jun 2018 8:33am
Cupboard
FWIW, you shouldn't be able to pass an MOT with different sized wheels on the same axle.
https://www.mot-testing.service.gov.uk/doc...class3457/
It's been like that for a while but I do know one car that's been through an MOT with a 13" wheel and three 14" wheels. The tyre profile made the overall rolling diameter pretty similar.
Post #713396 20th Jun 2018 9:37am
m3vert
Hi Landrover Anorak thanks, yeah I had thought that might be the case. I am trying to find the same style modular steel as I have fitted, but no joy so far. I assume the wheel will have a stamp in it somewhere telling me the offset and size???
Post #713397 20th Jun 2018 9:42am
hank
Another thing to be aware of, different rolling circumference will cause the ABS and traction control lights to illuminate (if fitted) as the control unit will sense wheels rotating at different rpm.
Lights should go out when matching tyres are refitted
Post #713412 20th Jun 2018 10:33am
