Home > Technical > Horn question |
Does anyone know if td5 defenders came with the wiring for twin horns? I think they should mount one behind each headlight but before I start trying to dig down to find the plug I wondered if anyone knew.
Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th Jun 2018 4:17pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2197 |
My 02' has wiring in place for twin horns (a 2way MQS connector if i recall). One is behind each front panel.
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
13th Jun 2018 4:45pm |
That’s just what I wanted to here thanks I’ll start digging Ray
13th Jun 2018 5:08pm |
Perfect Ray
13th Jun 2018 5:11pm |
Ok, another question. Does anyone know the wire colours for the o/s (drivers side uk) horn. I’ve had a good look and there are a pair of wires disappearing back up towards the wheel arch that are black and green/white. They are pretty stuck so if they are the correct wires I’ll drop the wheel arch cover Ray
13th Jun 2018 9:01pm |
They are the side repeater wires, hence why they are resistant to coming out
I cant remember from memory but i think it is either purple/black or purple/brown. Should be down towards the headlamp 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
13th Jun 2018 9:45pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
i just got one of these...
Click image to enlarge |
13th Jun 2018 10:08pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1186 |
Well I would start off on an I've got a bigger one but I know someone will better me. I've just mounted the twin trumpets inside my 110, just need to plumb in the air supply now. Doing a bit of a rearrangement so that the tank won't continually bleed out air via the Ashlockers.
Can get a photo tomorrow. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
13th Jun 2018 10:35pm |
There was another pair of wires going in the same direction that I’d convinced myself were the repeater wires but I’m usually wrong there were no other spare wires by the headlight so it must be one of the two pairs that went back towards the arch spat. I’ll have another look tomorrow Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th Jun 2018 11:00pm |
That looks fancy Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th Jun 2018 11:02pm |
I was thinking of a train horn or a Tour de France horn but I’ve got a spare defender standard one in the garage so that will do for now. Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th Jun 2018 11:04pm |
I have several but I keep killing them and they seem pathetic. What really took the biscuit was a police patrol car realising at the last minute he didn't want to be in the filter lane. Apparently a white 110 isn't big enough to see right next to him (I mean literally next to his door). Thankfully I managed to avoid a collision but from that moment started investigating better alternatives.
Then sourced a power steering relay box and pair of trumpets for the princely sum of £50 so a plan was hatched. Given I've already got an on board air setup (air con compressor style not weedy electric one) for the Ashlockers I don't think I'll struggle for air... Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
13th Jun 2018 11:09pm |
They're ******* loud (technical term there)
Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
15th Jun 2018 11:21pm |
Ray
15th Jun 2018 11:37pm |
