![]() | Home > Puma (Tdci) > Wiper park switch - FIXED! |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
A typical Ham home brew fix
heh, heh, I love these types of repair. Darren
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Top repair!
A friend of mine has a PCB/desktop vice just like that, but can't remember where he got it. You wouldn't happen to have a link? |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
https://www.amazon.co.uk/Universal-Holder-...B00TKGFUUU
Mine only came with the 3mm pins, not the silicone versions, but I boutght a few extra pins on ebay, and used some silicone tube from the model shop!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Good job.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Love this. Well done
![]() Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
The tricky bit is getting the new switch (or repaired one) back on, the clip will come off and you will lose it.
Solution = before you even try, cut a small piece of wood just big enough to jam into the recess in the switch above the clip making sure it is sub flush, then the clip can't move and the switch will go on first attempt. |
