Home > Puma (Tdci) > Wiper park switch - FIXED!
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The wipers on my Puma decided to stop parking in the correct place a couple of months back, and despite swapping the park switch, they still didn't park at the bottom of the cycle..
I pulled the switch apart, and the springy contact has a stress crack right across the weld point.. And as a consequence, the switch doesn't return to the correct terminal..
Deciding to try and save £14 for yet another switch, this will be number three, I have repaired the duff original..
It's simple to do.. The hard part is getting the switch body apart.. But it comes apart with careful application of a scalpel along the join line..
I soldered on a small piece of thin brass shim to act as a brace for the contact arm, and after a bit of filing to remove excess solder, and a minor fettle to get the contact arm in the right place, it went back together with no problems..
I've attached a couple of images to show what I've done..
The cracked contact..
The cracked contact (different view)
Soldered "repair".. Still needs cleaning up..
Contacts back in switch, repair and contact point arrowed.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #712133 12th Jun 2018 10:37pm
A typical Ham home brew fix Bow down
Post #712134 12th Jun 2018 10:43pm
heh, heh, I love these types of repair. Darren
Post #712135 12th Jun 2018 10:47pm
miker
Top repair!
A friend of mine has a PCB/desktop vice just like that, but can't remember where he got it. You wouldn't happen to have a link?
Post #712140 12th Jun 2018 11:42pm
Shax
https://www.amazon.co.uk/Universal-Holder-...B00TKGFUUU
Mine only came with the 3mm pins, not the silicone versions, but I boutght a few extra pins on ebay, and used some silicone tube from the model shop!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #712141 12th Jun 2018 11:46pm
Good job. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #712143 13th Jun 2018 12:03am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Love this. Well done Thumbs Up Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #712162 13th Jun 2018 9:46am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
The tricky bit is getting the new switch (or repaired one) back on, the clip will come off and you will lose it.
Solution = before you even try, cut a small piece of wood just big enough to jam into the recess in the switch above the clip making sure it is sub flush, then the clip can't move and the switch will go on first attempt.
Post #759193 17th Feb 2019 12:47pm
