Home > Maintenance & Modifications > x eng brake
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
x eng brake
can any one tell me there thorts on the x-eng brake for a puma ?
im thinking of perhaps getting one ?
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #71038 15th May 2011 8:11pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i guess it would remove the secondary store for transfair box oil, so you could ignore the annual recall.
Post #71082 15th May 2011 10:51pm
spudfan
Ireland
Anything you have'nt considered changing or modifying? Laughing Laughing 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #71086 15th May 2011 11:10pm
big steve
Lol there's always room for improvement
Steve 2015 2.2 tdci hardtop xs
Post #71099 16th May 2011 5:31am
mse
personally not a fan...there is no reasons why the original shouldnt work properly Mike
Post #71166 16th May 2011 5:33pm
noworries4x4
Apart from the fact it's covered in gear oil. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #71204 16th May 2011 8:38pm
big steve
lol on that point mine was done ages ago so i think i jsut facy improved hand brake lol
Post #71209 16th May 2011 8:55pm
noworries4x4
I converted my dads old trialer s1 gearbox with a disc set up from a dumper and jcb caliper and cable but i also used the over centre style lever fitted to plant, worked very very well held on 45deg no trouble If everything is under control you are not going fast enough.
No Worries 4X4
Post #71222 16th May 2011 9:45pm
mse
It shouldnt be though and if it is - im not one for fixing a solution by bodging a repair Thumbs Up Mike
Post #71255 17th May 2011 7:27am
TJ101
I certainly would not trust the standard handbrake, in some of the placed the trayback.. with a X brake gets left on some events !!!
Let alone have to clean the dam drum out after every event !!!
A X Brake is most definitely NOT a bodge repair California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #71432 17th May 2011 10:52pm
mse
I would have to disagree - although this an old chestnut of an argument.
I once had a similar view until a friend of mine, who happens to own his own LR business and trails/competes etc in a number of LR products educated me.
there are some simple mods (10 secs and free) that should see you never needing to clear out your drum...keep it well adjusted and you will be fine.
As he and a few others pointed out the pads in it are also a service item, just like you would change the drum brakes on a car when required - i bet there isnt anyone on here or other forums that thinks of it as they would the wheel brakes...and yet it is!!so you should service/check and maintain it - its not sealed for life fit and forget! Mike
Post #71436 17th May 2011 11:31pm
TJ101
I had one of the first X Brakes,, and been fitted to every comp vehicle since,, and never worn a pad out !
I also have been educated, and until they can seal a drum brake up, so that it will work, after being deep in water,, i will stick to a better system, of holding the vehicle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #71439 17th May 2011 11:47pm
leeds
Like many items there will be proponents for and against items be it batteries/lights/snorkels/protection etc.
We have X brakes fitted to two of our vehicles and it is just a matter of time before one gets fitted to our Puma.
I have found Si at X Eng to give excellent customer service and produces excellent products.
So yes I am a fan of X Eng and the X brake
Brendan
Post #71464 18th May 2011 8:44am
