Home > My Defender > V8 90 Project
Page 11 of 14 <123 ... 1011 121314>
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Lovely job on the engine Thumbs Up Thumbs Up Thumbs Up
What was wrong with it that lead you to strip it down like that? 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #662448 7th Nov 2017 6:24pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Cheers 👍🏻 Nothing directly wrong with it but a few seals seeped and when I removed the twin carbs a fuel line snapped, I couldn't find the replacement pipe so I decided to upgrade, the rocker covers and sump came off as I wanted to just check the internals due to the new cam and carb. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #664215 14th Nov 2017 3:19pm
Mash
So if buggsy having an update was long overdue what is maggies?
Well I have been able to do a few bits to her this week so I’m back on the rebuild Very Happy
First job was to drop the gearbox and t-box:
A little bit of cleaning to remove 30 yrs of crud gave me this:
Now I knew from the start a new chassis was going to be used for the project, it had a few areas that could of been patched and previously had a new rear crossmember, however I was not expecting this when I removed the gearbox crossmember:
As you can see there is nothing left from behind the crossmember, I have never seen rot this bad so here is another place to check.
With the box off I can start to overhaul the brackets/transmission brake etc:
More updates to come and hopefully a lot more often Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #710534 3rd Jun 2018 12:09am
The chassis is a bit scary behind the crossmember, I've seen rust before, but not nothing!
Does this not make you stop and buy a galv chassis?
I started to overhaul my handbrake, got bored and replaced it with an X-Eng version, even though it will never be used, it fascinates the MOT guy Cool QRZ 2e0vpf
Post #710543 3rd Jun 2018 6:36am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
My chassis was almost that bad when I removed the gearbox cross member. Once repaired the new galvanised cross member was bolted in with thick grease between the cross member and chassis.
Post #710544 3rd Jun 2018 6:39am
Mash
Well to ensure my new chassis doesn’t suffer the same fate I have so far:
Galvanised
2 pk marine grade paint
Internal dinitrol
And now an external dinitrol
So hopefully this means it’s as close to being Guernsey proof as practically possible. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #710618 3rd Jun 2018 7:41pm
L110CDL
Great update Mash Thumbs Up
What about taking the gearbox cross member off every so often just to check to see whats going on ? Clayton.
Keeper.
Post #710631 3rd Jun 2018 8:59pm
Mash
Always a good idea to keep an eye on hidden areas Clayton Thumbs Up
So a little more got done this weekend, she is slowly ( read very ) coming back together, a good rummage around found a few odds and sods I could move from storage and bolt on:
Just waiting on some bolts to add a few more bits, it’s mad how you can have all the right bits, place them in a draw and for items to vanish into thin air Confused Confused
Next on the list was the bulkhead, a few imperfections from the galvanising needed some filler:
Now I have a very small tolerance to body work, I can manage a small bit at a time when it comes to it so I needed something to distract me in between filling and sanding, cue the heater matrix, now just about every rivet of which there are many had signs of corrosion, so out with the drill Twisted Evil :
It’s amazing what protection a sticker offers:
All disassembled, worst of the rust remover then a coating in rust killer before a rust inhibiting primer with a final coat of satin black:
So slowly getting there Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #713103 18th Jun 2018 10:45pm
HK07
Hk07
Been that, done that, got the dirty T-shirt.
Amazing how those bulkheads differ ever so slightly.
Good fun ain't it? 2007 90 Puma - Love it - Best car I have ever owned.
Post #713108 18th Jun 2018 11:01pm
Mash
Oh it’s all good fun, and watching filler dry is much more exciting than all those overpaid numpties kicking a bag of wind Laughing Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #713111 19th Jun 2018 12:36am
I take it a new matrix is going in too?
top job Thumbs Up QRZ 2e0vpf
Post #713114 19th Jun 2018 6:37am
Mash
Cheers Greeni Thumbs Up yes a new matrix will be going in along with some insulation. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #713143 19th Jun 2018 11:39am
L110CDL
Nice work there Mash, always like a good cloths line full of landy bits Laughing Thumbs Up Clayton.
Keeper.
Post #713337 19th Jun 2018 10:27pm
Mash
Big news
I took this:
Then I added it with this:
And then I got this:
Now I am a while away from dropping in the engine as I want to sort the fuel/brake lines etc first, does anyone know the distance from the front crossmember to the bell housing so I can correctly align it as I forgot to measure it Embarassed I would go off the diff using the rear prop but as I have changed the rear axle I’m unsure if this will of effected the distance.
I 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #729101 15th Sep 2018 4:58pm
L110CDL
Good feeling you get when adding stuff to the new chassis Wink Clayton.
Keeper.
Post #729342 16th Sep 2018 8:20pm
