Home > Maintenance & Modifications > Ramps
Page 2 of 4 <1234>
sako243
blackwolf wrote:
I was brought up in the school that believed you should never use breeze blocks, bricks, or any material like that, since they they can crumble and kill you. Timber is good, however, since it doesn't crumble.
It is useful for many purposes to have a supply of sawn blocks of regular size to build cribbing.
The major benefit is that timber over steel and concrete gives you warning when it's about to go. Not much but it'usually creak and crack before going. Steel and concrete just tends to go.
May not give you much but some is better than one if it means you can scrabble out from underneath.
I've gone the route of a 4" fence post cut up and screwed together to make it wider, I happened to have a load of posts lying around where the bottoms had rotted out. At my parents we had a 3.5t mini digger and a barn so ended up with a pit Razz Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #709389 27th May 2018 7:52am
NickMc
When I have to I use axle stands and a trolley jack....you’d almost think that’s what they’re designed for Whistle
(Have to that is as I have four and two post lifts and don’t lie on the ground anymore, that’s for
Apprentice’s Razz )
Post #709592 28th May 2018 5:28pm
Ramps? Who needs them?
Back in the 1980s I needed to do a spot of welding on my 86" chassis for the MoT. I've never liked overhead welding, so this was the obvious solution. I subsequently rebuilt the vehicle onto a new galvanised chassis, since the old one was (by the standards of the time) beyond economic repair.
The vehicle is actually supported by the roll hoop which is resting on a spare inflated tyre.
It was surprising how hard it was to tip over (it needed a 6' Hilift under the bulkhead outrigger to reach the point of balance, a 4' wasn't tall enough) and how easy to tip back (I only had to jack the roll hoop about 18" before it rolled back upright and thoroughly tested the strength of my welding) . I had made sure that there was very little fuel in the tank, and had removed the battery.
Post #710716 4th Jun 2018 1:11pm
Caterham
X4SKP wrote:
Hello Doc P
I agree with the comments so far...
For general 'easy to get under work', I took 4 'standard' Metal Ramps,
added some extra metal work, base level cross elements to prevent splaying
and to allow the metal ramps to engage with wooden base blocks, these also
'grip' better on our gravel hard standing area.
On top of these Ramps I added wider run up ramps, which were old Pipe transporter
spacers, which add a little extra height and help with the 'progressive' drive up...
stop at the 4th indent!
I went the extra step when applying Dinitrol of lifting the Defender off each Ramp,
reversing the rear two Ramps so that they face inwards (matching the front Ramps)
then resting the whole Land Rover on a combination of Oak Sleeper Blocks and 4 smaller
Oak Blocks 'profiled' to engage with the Axle load points.
Over all this raise the Defender just short of 0.5M and with carful placement of all elements
the only real movement was within the suspension elements.
Good Luck...
I also thought this looked a bit scary until I noticed the 'two safety lines' holding the back up should the wooden blocks etc slip / move. Bow down
Post #710737 4th Jun 2018 3:33pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Thanks to all....................I'm just not sure if I'm any the wiser! Confused
Might hire a mini digger then.
Ian
Post #710752 4th Jun 2018 5:31pm
Markez79
X4SKP wrote:
auto jacking is possible...
errrr! Who makes this?! Never seen this before but looks clever....and expensive!
Post #751394 15th Jan 2019 10:49am
I rather hope that there is some positive locking device on that to eliminate the possibility of accidental deployment. Also if there is a front one, I wonder if it is hinged at the front or back.
The possibilities for a spectacular failure are endless......
Post #751406 15th Jan 2019 11:38am
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
I'm needing to change my clutch soon, and I'm now wondering if some sleepers would give me enough room Shocked
Post #751411 15th Jan 2019 11:48am
Mo Murphy
That's the Bowler jack that was fitted for one of the desert comps IIRC.
50 Shades of Pennine Grey
Post #751419 15th Jan 2019 12:56pm
Markez79
Thanks Thumbs Up
Post #751428 15th Jan 2019 1:33pm
hank
Interesting method I saw on youtube recently Very Happy
 > 110 XS Double Cab
Post #751435 15th Jan 2019 2:11pm
I don't think that that is a method I would recommend, and I don't think his risk assessment was very thorough!
10/10 for creativity though.
Post #751449 15th Jan 2019 3:05pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Shocked balancing on some road wheels carrying a transfer box..... nice
Post #751469 15th Jan 2019 4:48pm
Caterham
I often wonder how accidents happen......
Post #751471 15th Jan 2019 4:50pm
^^ I imagine in his case it was defective birth control!
Post #751475 15th Jan 2019 5:14pm
Page 2 of 4 <1234>
