![]() | Home > Maintenance & Modifications > Ramps |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
When I have to I use axle stands and a trolley jack....you’d almost think that’s what they’re designed for
![]() (Have to that is as I have four and two post lifts and don’t lie on the ground anymore, that’s for Apprentice’s ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17989 ![]() ![]() ![]() |
Ramps? Who needs them?
Back in the 1980s I needed to do a spot of welding on my 86" chassis for the MoT. I've never liked overhead welding, so this was the obvious solution. I subsequently rebuilt the vehicle onto a new galvanised chassis, since the old one was (by the standards of the time) beyond economic repair. The vehicle is actually supported by the roll hoop which is resting on a spare inflated tyre. It was surprising how hard it was to tip over (it needed a 6' Hilift under the bulkhead outrigger to reach the point of balance, a 4' wasn't tall enough) and how easy to tip back (I only had to jack the roll hoop about 18" before it rolled back upright and thoroughly tested the strength of my welding) . I had made sure that there was very little fuel in the tank, and had removed the battery. ![]() Click image to enlarge |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
I also thought this looked a bit scary until I noticed the 'two safety lines' holding the back up should the wooden blocks etc slip / move. ![]() |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Thanks to all....................I'm just not sure if I'm any the wiser!
![]() Might hire a mini digger then. Ian |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 ![]() |
errrr! Who makes this?! Never seen this before but looks clever....and expensive! |
I rather hope that there is some positive locking device on that to eliminate the possibility of accidental deployment. Also if there is a front one, I wonder if it is hinged at the front or back.
The possibilities for a spectacular failure are endless...... |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 267 ![]() ![]() ![]() |
I'm needing to change my clutch soon, and I'm now wondering if some sleepers would give me enough room
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2407 ![]() ![]() ![]() |
That's the Bowler jack that was fitted for one of the desert comps IIRC.
Thanks
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2362 ![]() ![]() ![]() |
Interesting method I saw on youtube recently
![]() > 110 XS Double Cab |
I don't think that that is a method I would recommend, and I don't think his risk assessment was very thorough!
10/10 for creativity though. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
I often wonder how accidents happen......
^^ I imagine in his case it was defective birth control!
