![]() | Home > Puma (Tdci) > Puma 2.4 smoke on cold start |
A little bit of white smoke is normal, it's deliberately rich.
It's also richer than usual because the battery voltage is low so the injectors don't work as well. A weak battery will cause more white smoke. Other things that cause excessive white smoke are the EGR system being dodgy and I believe that the VCV can cause issues like that too. Certainly misfires would come from there. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Glow plugs possibly they’re a sub standard quality in the tdcaye. Don’t buy the Berus they’re rubbish.
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
I had the same issue and it turned out that my engine is gone. It also used to burn lots of oil. Do you loose engine oil? Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
Jimmy B Member Since: 11 Nov 2017 Location: Cumbria Posts: 51 ![]() ![]() |
I am thinking of trying the vcv next. The egr is deleted with remap and also blanked off. The battery is in good condition. It’s had a new set of glow plugs as I found 2 had failed, they were Berus tho. It’s not using any oil or water.
Lots of people seem to have the same problem and say it’s normal for them to smoke on startup but it isn’t normal, mine never use to and I regularly use 2 pumas at work which are the same age but with 100 000 and 120 000 miles with absolutely no smoke or missfire |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
They seem variable, but mine has blown clouds of white smoke on a properly cold start from day one in 2011.
Jonno do you ever get a missfire/rough idle or just smoke?
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3675 ![]() ![]() ![]() |
Mine generally lives in a garage and i notice no smoke at all turning the key immediately without letting the glow plug light extinguish, if I park outside on a cold night and forget to do the glow plug light thing I get some smoke and a few seconds of rough running, if I let the glow plug light extinguish its fine. I would therefore suggest before you assume the worst the glow plugs would be worth checking. DEFENDER 90 TDCI XS,
Glow plugs were my first thought and after stripping the intake manifold to get to them I found 2 had failed, so pleased with my finding I replaced all 4 and reassembled but the next morning it had made no difference 😩
Is the glow plug relay ok? I’ve replaced a few of them along with shorted glow plugs.
I’ve just put a volt meter on the glow plugs to check the supply and it’s only showing about 10v whereas the battery shows 12.3 is this normal?
Mine never had smoke, now it’s exactly as you describe. Quite a list of checks to do, it seems, what does everyone think is the best order?
Note, fuel usage normal. Oil usage normal. MAF sensor fault, not yet rectified. Lots of oil sprayed in/around the MAP. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
AndreB Member Since: 23 Jan 2021 Location: Brielle Posts: 11 ![]() ![]() ![]() |
I will follow, mine has just the same. White smoke on a cold start, no oil consumption or any other alarming signals. Engine runs smoothly. Had:
Defender 90 TD5 2001 - 225.000 km Defender 110 TD5 - 2000 - 120.000 Have: Defender 90 Puma 2.4 2010 - 211.000 km Instagram: https://www.instagram.com/landrover_diary/ |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Not sure why this thread didn't turn up in my search before I posted this:
https://www.defender2.net/forum/topic80900.html In it you'll see I found a bit of corrosion around the lug and stud connection between the harness and the wire leading to the glow plugs. After cleaning it the resistance dropped from 11Ω to 1.4Ω. While 11Ω is still enough to trigger a continuity beep in a Fluke meter it can't hurt to have a look at this, maybe yours is worse? If you have a DMM it's a simple as a resistance check between the stud and any of the glow plugs, I used sharp probes on freshly cleaned surfaces. Solved the bowel problem, working on the consonants... |
