Home > Puma (Tdci) > Puma 2.4 smoke on cold start
Jimmy B
My 2010 2.4 puma has begun smoking quite a lot when starting from cold first thing. It lasts for about 30 seconds and is worse when the air temperature is colder. The smoke is thick greyish and there is sometimes a misfire as well. There are lots of threads with other people having the same problem but no real answers as too what is causing it. What do people think?
Post #707959 18th May 2018 8:12pm
Cupboard
A little bit of white smoke is normal, it's deliberately rich.
It's also richer than usual because the battery voltage is low so the injectors don't work as well. A weak battery will cause more white smoke.
Other things that cause excessive white smoke are the EGR system being dodgy and I believe that the VCV can cause issues like that too. Certainly misfires would come from there.
Post #707973 18th May 2018 8:58pm
NickMc
Glow plugs possibly they’re a sub standard quality in the tdcaye. Don’t buy the Berus they’re rubbish.
Post #707994 18th May 2018 11:12pm
diduan
Bulgaria
I had the same issue and it turned out that my engine is gone. It also used to burn lots of oil. Do you loose engine oil? Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #708013 19th May 2018 6:37am
Jimmy B
I am thinking of trying the vcv next. The egr is deleted with remap and also blanked off. The battery is in good condition. It’s had a new set of glow plugs as I found 2 had failed, they were Berus tho. It’s not using any oil or water.
Lots of people seem to have the same problem and say it’s normal for them to smoke on startup but it isn’t normal, mine never use to and I regularly use 2 pumas at work which are the same age but with 100 000 and 120 000 miles with absolutely no smoke or missfire
Post #708030 19th May 2018 9:26am
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
They seem variable, but mine has blown clouds of white smoke on a properly cold start from day one in 2011.
Post #708175 20th May 2018 11:52am
Jimmy B
Jonno do you ever get a missfire/rough idle or just smoke?
Post #708180 20th May 2018 12:20pm
LR90XS2011
Mine generally lives in a garage and i notice no smoke at all turning the key immediately without letting the glow plug light extinguish, if I park outside on a cold night and forget to do the glow plug light thing I get some smoke and a few seconds of rough running, if I let the glow plug light extinguish its fine. I would therefore suggest before you assume the worst the glow plugs would be worth checking. DEFENDER 90 TDCI XS,
Post #708181 20th May 2018 12:23pm
Jimmy B
Glow plugs were my first thought and after stripping the intake manifold to get to them I found 2 had failed, so pleased with my finding I replaced all 4 and reassembled but the next morning it had made no difference 😩
Post #708182 20th May 2018 12:36pm
NickMc
Is the glow plug relay ok? I’ve replaced a few of them along with shorted glow plugs.
Post #708191 20th May 2018 3:08pm
Jimmy B
I’ve just put a volt meter on the glow plugs to check the supply and it’s only showing about 10v whereas the battery shows 12.3 is this normal?
Post #708210 20th May 2018 6:20pm
Grenadier
Mine never had smoke, now it’s exactly as you describe. Quite a list of checks to do, it seems, what does everyone think is the best order?
Note, fuel usage normal. Oil usage normal. MAF sensor fault, not yet rectified. Lots of oil sprayed in/around the MAP. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #708215 20th May 2018 6:29pm
AndreB
Netherlands 2010 Defender 90 Puma 2.4 HT Galway Green
I will follow, mine has just the same. White smoke on a cold start, no oil consumption or any other alarming signals. Engine runs smoothly. Had:
Defender 90 TD5 2001 - 225.000 km
Defender 110 TD5 - 2000 - 120.000
Have:
Defender 90 Puma 2.4 2010 - 211.000 km
Instagram: https://www.instagram.com/landrover_diary/
Post #926999 24th Oct 2021 8:43pm
agentmulder
Kuwait
Not sure why this thread didn't turn up in my search before I posted this:
https://www.defender2.net/forum/topic80900.html
In it you'll see I found a bit of corrosion around the lug and stud connection between the harness and the wire leading to the glow plugs. After cleaning it the resistance dropped from 11Ω to 1.4Ω. While 11Ω is still enough to trigger a continuity beep in a Fluke meter it can't hurt to have a look at this, maybe yours is worse?
If you have a DMM it's a simple as a resistance check between the stud and any of the glow plugs, I used sharp probes on freshly cleaned surfaces. Solved the bowel problem, working on the consonants...
Post #927137 25th Oct 2021 11:39pm
