![]() | Home > Technical > Td5 brake flexi |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Does anyone know if shb500230 flexi hoses fit a td5 110 ? Or if not does anyone know the correct part number for front flexi hoses for a 2004 td5 110 csw?
Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
I wasnt sure if it would be worth putting braided lines on for a standard braking system. The original flexis are fine at 14 years old but I got an advisory for the front brake pipes so thought I'd buy new flexis just to make the job easier. Ray
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
yes 04 and onwards front flexi hoses pipe changed too this type |
Hmmmm, mine is a 2004 on a 53 plate Ray
Click image to enlarge 04 and onwards front flexi hoses pipe held in place with metal clip at both ends or NRC 7874 on up to 04 ![]() |
That's perfect thanks
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
I like my braided hoses from Llama 4x4
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
^^^^ I've already suggested them, I know how good they are too
I'll check them out
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Check if it’s a nut or a clip that holds it on at the spring hanger, that’s the difference in the two hoses
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
Just a word of warning, my original flexi hose after 16 years started leaking brake fluid due to corrosion... only 2 days after it passed the MOT.
The corrosion wasn't apparent until after it was taken off and MOT inspectors aren't allowed to pull the car apart to find issues. |
i had 5 year old braided hoses fail in MOT brake test
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
I think I saw on here the ones that do away with the swivel clip bolt
| All times are GMT |
