Home > Technical > Td5 brake flexi
mk1collector
Td5 brake flexi
Does anyone know if shb500230 flexi hoses fit a td5 110 ? Or if not does anyone know the correct part number for front flexi hoses for a 2004 td5 110 csw?
Ray Ray
My build thread
Post #707942 18th May 2018 7:22pm
williamthedog
Why put standard hoses back on? Why don't you call llama 4x4 and get him to make you a braided set up? Very good lines and price Thumbs Up
Post #707954 18th May 2018 7:57pm
mk1collector
I wasnt sure if it would be worth putting braided lines on for a standard braking system. The original flexis are fine at 14 years old but I got an advisory for the front brake pipes so thought I'd buy new flexis just to make the job easier. Ray
My build thread
Post #707955 18th May 2018 8:02pm
dorsetsmith
Re: Td5 brake flexi
Ray
yes 04 and onwards front flexi hoses pipe changed too this type
Post #707958 18th May 2018 8:09pm
mk1collector
Hmmmm, mine is a 2004 on a 53 plate Ray
My build thread
Post #707960 18th May 2018 8:13pm
dorsetsmith
held in place with metal clip at both ends
or NRC 7874 on up to 04
Post #707966 18th May 2018 8:22pm
mk1collector
That's perfect thanks Thumbs Up I'll get underneith tomorrow and have a look. Ray
My build thread
Post #707997 18th May 2018 11:33pm
excossack
I like my braided hoses from Llama 4x4 Smile 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #708124 19th May 2018 9:18pm
williamthedog
^^^^ I've already suggested them, I know how good they are too
Post #708125 19th May 2018 9:27pm
mk1collector
I'll check them out Thumbs Up Ray
My build thread
Post #708130 19th May 2018 9:40pm
NickMc
Check if it’s a nut or a clip that holds it on at the spring hanger, that’s the difference in the two hoses Thumbs Up
Post #708137 19th May 2018 10:24pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Just a word of warning, my original flexi hose after 16 years started leaking brake fluid due to corrosion... only 2 days after it passed the MOT.
The corrosion wasn't apparent until after it was taken off and MOT inspectors aren't allowed to pull the car apart to find issues.
Post #708292 20th May 2018 11:25pm
dorsetsmith
i had 5 year old braided hoses fail in MOT brake test Exclamation
Post #708306 21st May 2018 8:05am
ibexman
I think I saw on here the ones that do away with the swivel clip bolt
Post #708310 21st May 2018 8:23am
